08-27-2016, 01:36 PM | #1 |
I'm looking forward to that!
09-04-2016, 07:50 PM | #2 |
Jimwildman,tried your set up and ended up with a 3/4 rise,I'm not joking.
09-06-2016, 06:08 AM | #3 |
how is it with your weight on it?
I took it off road yesterday and 8m thinking its a bit soft. I cut away a bit of the old mount so that it can get more angle, as well as to shape the part to,allow more angle before touching the swing arm. so my mount is 3/4" forward but 1/2 imch lower. again the amount of change in leverage is a bit extreme. i might make a change at the top of the mount to try a bit less leverage. |
09-06-2016, 08:29 PM | #4 |
tonight in an effort to reduce the effect of leverage i did basically the same thing at the top of the shock, the part required alot more shaping and I plan to weld this one, bolt is good for testing but alot of weight goes against the tank mount, so welding it to the old mount will solve that.
im almost flatfooted siting on the bike now. and its about half as soft. so better. its probly as good as its gonna get with this shock. even after welding this my old top mount will still be usable, there will just be a second placement for it. |
09-07-2016, 10:53 AM | #5 |
I'm looking forward to pics of that, Jim.
09-08-2016, 12:59 PM | #6 |
here is the chain side, as you can see i got greedy and went for too much drop, result is I had to heat the top frame rail and dent it with a ball peen, to make room for removing the bolt.
im glad i did tho as the seat is 32" high and so is my insem. |
09-08-2016, 12:59 PM | #7 |
seat height
09-08-2016, 01:01 PM | #8 |
other side
09-08-2016, 01:04 PM | #9 |
seems i was holding the ipad upside down for some pics. embassasing.
here is a side view of the bike all reassembled. i had to remove the plastics, seat, tank, air box, and move several wire looms out of the way to do this. |
09-08-2016, 09:40 PM | #10 |
I think I put my neck out of place. It is also hard to see anything with the tiny pictures.
09-09-2016, 09:26 AM | #11 |
The high speed wobble is diminished/gone. could it be the geometry was off due to being soo jacked up in the rear?
From what I know a small change in the rake and trail of a bike can reflect bjg changes in the stability. Dropping the rear a few inches would have a small effect on the rake and trail. I allways blamed the tires for the wobble. Rake effects trail, so raising the rear lowers trail and makes the bike easy to turn, but less stabil at high speed straight line. lowering the rear increares rake and trail and increases the sraight line stability, wile incresing the effort required to turn in on a corner. Im going riding at Limestone NY Tommorow so i will get a chance to test it in a big way. |
09-12-2016, 09:11 AM | #12 |
does anyone know the spring weight on the hawks rear shock?
I've found a dimensionally vorrect shock, with adjustable dampening and preload with a spring weight of 1200. got me wondering what the stock shocks spring is rated at. my bike performed well this weekend, but I did find myself wanting to add dampening. |
09-12-2016, 09:24 AM | #13 | |
09-12-2016, 02:34 PM | #14 | |
09-23-2016, 05:58 PM | #15 |
Try CO2 in yer tyres.... it's temp sensive..
as the tyre heats up the pressure will increase go on to the dirt where less heat is generated and the pressure will drop... ..
