05-30-2016, 11:14 AM | #16 | |
I recommend against flux core only. Get a true MIG that will accept shielding gas and then the choice is yours, in terms of using gas or flux core. I also recommend a welder with infinite voltage control, rather than four, five or six settings. My voltage control goes from 1-10, and I spend most of my time between either 2-3 or 3-4 on the dial. the finite control is very useful, whereas limited controls might either not give the penetration you need or might burn right through (which is quite frustrating). I bought a Miller 175 about 10 years ago, but since then, Eastwood has come out with a decent MIG welder that has infinite voltage control for cheap. If you want a 120VAC machine, check out http://www.eastwood.com/mig-welder-1...5a-output.html The price is certainly right. I have a friend with that welder, and I like it just fine for small jobs. It uses Tweco consumables, so parts are easy to find.
05-30-2016, 11:15 AM | #17 |
The other way is with a spool gun. No need to worry about keeping the hose straight, since it will only be providing gas.
05-30-2016, 11:47 AM | #18 |
I picked up a Harbor Freight 170 240 mig that has a gas provision. It was when they were having a sidewalk sale so it could have been a return or an overstock. Anyway I got it for $75. They told me I had 5 days to return so test it. I called my dad over who is a retired welder that worked for Pratt & Whitney welding jet engines so he knows enough about welding. He could not believe how good it welded, especially for $75. He said this is perfect for a homeowner but you can't weld a battleship with it.
If you plan on using it everyday buy a good one. Hobart, Miller, Lincoln otherwise HF is good. |
05-30-2016, 01:15 PM | #19 |
Flux core wire feed and MIG are often used to describe the same machine/process but they're very different. MIG, metal insert gas, uses no flux material using a gas as the shielding material and makes a cleaner weld. Different gasses have different uses and results. Flux core wire feed is easier than arc but still leaves the flux that has to be cleaned off. I believe flux core wire will generally give more penetration than MIG with the same power, also making it harder to weld thin stuff than with MIG.
05-31-2016, 03:42 AM | #20 |
Weld, I use Flux c just because I'm a simple kind of man. Easy for cheap bastards.
Yes more options with digital control, wise choice if economical. More brand choices out now vs then . ESAB brand has really exploded on to the market (explosion?bad word choice?)
05-31-2016, 10:25 AM | #21 | |
I'm no welder and this thing is for super-light duty, plus it's just got a switch for adjusting the juice (no knob) but I can honestly say that I've been able to stick together everything I've tried. Can't beat it for the price for how little I weld. It has yet to overheat on me but I'm no speed demon.
05-31-2016, 11:13 AM | #22 | |
I'm not saying break the bank and buy a digital machine; I'm saying choose one with a voltage control that is more like a volume knob. Again, the Eastwood product is quite economical and capable. Hard to beat those features at $279.99.
05-31-2016, 07:32 PM | #23 |
Hey Weld funny story I was patching my snow plow with a spool of flux core and the welds were coming out like crap. My dad stopped by to take a look and he said that the monster fan I set up blowing the smoke from my face was also blowing away my shielding gas from the flux. I thought i was being smart and safe but I was ruining my weld. If you were there you would have been shaking your head like my dad. Those little jewels of information would take a rookie welder like me countless hours to figure out but pros like you and my dad just look and tell immediately what is wrong.
As far as duty cycle, I spend an hour of prep for 5 minutes of welding which is why my dad said you can't weld a battleship with it, but for me it's perfect. I took a TIG welding class and oh boy was that fun. Problem is you cant get a decent TIG for 75 bucks.... and I kinda cheap. TIG is pretty but man it is HOT I had the glove smoking and you don't notice until your pointer finger is roasting. |
05-31-2016, 10:30 PM | #24 |
I got the cheap HF 90 amp welder a number of years ago to weld in some patch panels on a vw bug project but only after lots of practice with different settings etc. Also switched to different/better wire than the HF stuff. http://www.amazon.com/BA71TGS-030-In...e+welding+wire
Much better results, less spatter. Rojo
'15 RX3 (Rojo's) '15 RX3 (marzhere's) '16 TT250 |
05-31-2016, 11:05 PM | #25 | |
06-01-2016, 07:44 AM | #26 |
OP, do you find any performance gains after killing the cat?
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid |
06-01-2016, 10:38 AM | #27 |
RonB conducted cat surgery on his Hawk. He didnt have it long but I think he did put some miles on it afterwards - perhaps enough to tell a difference.
06-01-2016, 10:41 AM | #28 | |
It was only useful within a small range of metal thickness, so I set my sights on a Miller; haven't looked back since.
06-01-2016, 10:44 AM | #29 | |
06-01-2016, 10:47 AM | #30 |
This quickly degenerated into a welding thread. That's probably on me.
Not that this is apples to apples, but I removed a cat on a 50cc scooter, changed the jetting to suit and added a pod air filter. The results were such that I could travel at about 40mph on level grade, whereas before the mods the best I could get was 30mph.
