Old 04-22-2016, 03:20 PM   #16
jet321   jet321 is offline
Yeah moto! I'm going to buy a hawk because of your videos as well man! Keep them up and get a good mic! You've been killing it!
Old 04-22-2016, 05:12 PM   #17
Adam Rinkleff   Adam Rinkleff is offline
Where are these videos? We haven't seen them?
Old 04-22-2016, 06:02 PM   #18
traygiddens   traygiddens is offline
https://www.youtube.com/channel/UCfs...sZwINrc4KSbAlQ
Old 04-22-2016, 10:52 PM   #19
pistolclass's Avatar
hey Adam I think MotoCheez get salesman of the year award. We just picked up 3 hawks one for me. one for Little Cheez and one for Mr V. Another buddy of mine just bought the Blizzard and loves it.
Old 04-23-2016, 11:12 AM   #20
CQARIZONA   CQARIZONA is offline
Welcome MotoCheez..Like others, I recently bought a Hawk after watching your great videos.. Keep up the good work...
CQ
in Sonoran desert Arizona
2015 Haosen Hawk 250
2003 Royal Enfield Bullet 500
Old 04-23-2016, 11:20 PM   #21
xposur   xposur is offline
MotoCheez, you have a 110 jet on your hawk? Did you try out a 115 and have better results with the 110?
Old 04-24-2016, 08:57 AM   #22
Stoneman   Stoneman is offline
In my quest for information on the Hawk among others, i found your videos on U tube before i found China Riders. Keep up the good work! Yeah and they should give you a cut!
Old 04-24-2016, 10:31 AM   #23
MotoCheez   MotoCheez is offline
MotoCheez's Avatar
The 115 was too much, it loaded up a little on me.
Old 04-24-2016, 10:33 AM   #24
MotoCheez's Avatar
Originally Posted by BlackAcid View Post
Hope your getting a cut from the increased sales at txpowersports. You helped me make the decision to get the hawk and your videos great.
HAHA,
I don't get a cut... I wish I could get better discounts too!
Old 04-24-2016, 02:21 PM   #25
Azhule   Azhule is offline
Just watched your latest video Cheez .
But depending on what you bought for the "Octane Booster/Additive", I would suggest you save your $, most of those barely boost the octane and have little overall effect and some can be extremely harmful depending on what is packed in the bottle.
If anything, might I suggest you try adding a fuel additive that helps with the "fuel combustion" process, one like Lucas Oil Companies "Fuel Treatment/Tune Up In A Bottle", it is an inexpensive and decent fuel additive that contains "PIB" (PolyIsobutylene), basically helps with "Fuel Tension/Fuel Molecule Size". Can find it everywhere in small bottles ($6 or so) up to gallon jugs ($20 or so after coupons codes, Advance Auto)
http://lucasoil.com/products/fuel-tr...fuel-treatment
Or (my personal preference if you can wait to have it delivered), would be to buy a gallon of Schaeffers Nuetra 131, not only does it clean the fuel system and 'help with fuel tension/combustion process', it can also be used as a fuel/engine/transmission/gear box/hydraulic oil/system cleaner. Found on Amazon for cheap ($25 a gallon shipped to your door ). I have personally seen this turn SOLID chunks of carbon into LIQUID BLACK GOO over night. I was working on a 1992 Honda Accord EGR system, it was completely plugged up so I filled the intake plenum/EGR Port with a few cup fulls of Neutra 131 and let it soak over night the result was nasty but clear... I have never seen carbon turn back to a goo in such a way... it left the metal CLEAN and 'SHINY' with almost no work/effort at all
http://www.schaefferoil.com/neutra-fuel-stabilizer.html
How all you can use Schaeffer Neutra 131 found in this PDF
http://www.schaefferoil.com/documents/32-131-td.pdf
I used to use Lucas all the time as I could get it 'locally for cheap', but Amazon ships me Schaeffer Neutra gallons for about the same price of a gallon of Lucas... Schaeffer has been making top shelf products for almost 180 years... Lucas makes some decent and some 'snake oil' type products for dozens of years... it's a 'no brainer for Schaeffer' when you read of the ~180 History
Old 04-24-2016, 02:40 PM   #26
d2ebbie   d2ebbie is offline
hawk
how fast does the hawk go
Old 04-24-2016, 06:42 PM   #27
MotoCheez's Avatar
I never use those additives, Just this one time because I THOUGHT I may have filed the Hawk with 89 octane. But I do agree with you on that!
Old 04-24-2016, 06:43 PM   #28
MotoCheez's Avatar
65 on a flat pushing 70 if I am lucky. GPS confirmed
Old 04-24-2016, 07:33 PM   #29
SeerAtlas   SeerAtlas is offline
gearing?
what gearing you running cheez?
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 04-24-2016, 09:45 PM   #30
MotoCheez's Avatar
17t front with stock rear 50t
