Old 04-11-2016, 11:00 AM   #16
Azhule   Azhule is offline
Originally Posted by dpl096 View Post
Did you put the rubber seals back on afterwards ?
Yes, if you can make sure BOTH sides have seals (some new bearings have seals on 1 side only, just clean up and re-use your old seals to cover both sides if needed ), this way dirt/dust/water/debris of any kind will stay out of the bearings
Old 04-11-2016, 11:07 AM   #17
This is why this place rocks! Did you put the rubber seals back on afterwards ?
Thanx Spud
Yes, you need the seals to keep the grease inside the bearing, and to keep water and dirt outside the bearing. This is why you want 2RS bearings, with two rubber seals. You don't want metal seals, which cannot be removed to add extra grease, and which don't protect as well as rubber seals.
Old 04-11-2016, 11:13 AM   #18
Darn I answered almost everything... but I forgot to mention about those pesky "Metal Sealed" ones, thanks for reminding me Spud I haven't seen that style in a while so I forgots about them
Old 04-11-2016, 11:21 AM   #19
I like that wheel bearing removal kit.
When adding grease to a bearing, a needle attachment for a grease gun is helpful.
Old 04-11-2016, 11:26 AM   #20
Lee R   Lee R is offline
Lee R's Avatar
Originally Posted by Juanro View Post
Lee, I do also, my bearings have 16K km on them and they're smooth as silk, but as you said it's cheap insurance to change them anyway.
Thanks Juanro, I'm glad yours are holding up. I'm a little worried as the ride report from an early RX3 has wheel bearing failures as well (then no more ride report, I think he made it from China to Turkey).
Seems cheap insurance as you said, to just punch out the current ones and drop in some known higher quality pieces.
Love the pictures from down south by the way, I'm planning a trip with a friend but it's a few years out to head south and I need to work on my Spanish a bit to get the most from it.
Lee
Old 04-11-2016, 11:33 AM   #21
I'm going to check my front bearings once again. If I have the correct size in stock, I am going to replace them, also.
Old 04-11-2016, 11:35 AM   #22
If I were starting over again, I would definitely get the complete Pit Posse Kit, with the plastic case. I have spent as much on the individual parts, and I still lack a few collets and the nice plastic case.
I use either my finger, or a welding flux brush to apply extra grease to the bearings.
Old 04-11-2016, 12:01 PM   #23
Juanro   Juanro is offline
Juanro's Avatar
I seem to recall (but can't find the source right now) that the bearing problems the guy ("Silkrider" or something like that?) had were caused by failing to replace some spacer when dismounting the rear wheel?
Old 04-11-2016, 12:08 PM   #24
Lee R's Avatar
That would definitely make for some unhappy bearings. It's too bad we never got a conclusion to that ride report!
Old 04-11-2016, 12:25 PM   #25
I speculated the Silk Road Rider might not have tightened the axle adjusting nuts properly. However, I am now inclined to believe the problem might reside with dry, perhaps inferior wheel bearings.
Ordinarily, I would have noticed a notchy wheel bearing a long time before it fractured. However, my Shinko, 244 rear tire lasted so long, I didn't remove the rear wheel for inspection as often as usual.
Old 04-11-2016, 12:50 PM   #26
Juanro's Avatar
Come on, are you going to tell me that you don't dismantle the whole bike, just for the fun, every other weekend?
Old 04-11-2016, 01:51 PM   #27
Old 04-11-2016, 01:52 PM   #28
I'm pleased to report the front wheel employs two, 6302 2RS bearings, and they were in excellent condition.
Old 04-11-2016, 03:02 PM   #29
keithmaine's Avatar
once again
Old 04-11-2016, 05:00 PM   #30
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Rear Hub Bearing Sizes
Rear Hub Bearing, Sprocket Side: 6202 2RS
Rear Hub Bearing, Brake Rotor Side: 6302 2RS
Sprocket Carrier Bearing: 6004 2RS
Do you have a link where I can buy the higher quality Japanese bearings?
