12-30-2015, 01:19 PM | #16 | |
Alex1nonly, looks like you need to grab a 6 pack of your favorite beverage, a short stool and a set of tools, and do what we all do. Take your time and go over each nut and bolt, make sure everything is secure and all cables are adjusted correctly. It will save you a ton of grief in the future.
12-30-2015, 09:46 PM | #17 | |
The little bike runs rough, it keeps spuddering unless its wide open (which my son is OK with). I tried to play with the 2nd screw on the carburetor (not the idle screw) with no results. It didn't idle when I got it, ordered a new carburetor and found the problem was the intake loose with an air leak. How do I check the Jet? Any suggestions to fix it would be apprediated |
12-31-2015, 02:25 PM | #18 | |
With both of my 150's, both my 200's and now my 230, they all seem to like to be jetted around a #115 main jet and a #30 pilot, give or take. I now live at 3000 feet and I used to live in Sacramento at about 300 feet and those jets generally performed well at both. Make sure the needle clip in the slide is in the middle slot, if there are optional slots available. Set the air (mixture) screw at 1.5 turns out to start with and go from there. Also, I've yet to have a CB that didn't come with tight valves (except my Q Link). Let the bike set overnight, find the valve specs and set them accordingly, ice cold.
03-02-2016, 11:14 AM | #19 |
assembly of 250 Blaze?
love the video. i just got one of these e250 blaze bikes and it did not come with instructions on how to assemble from the crate. any way you can give me a link. or take close up photo,s as to how the front fender, speedo, ignition switch, blinker bars are attached. i,m new to this site. help from anyone is appreciated. thanks.
03-02-2016, 05:18 PM | #20 | |
Tags |
blaze 250 |
