Old 12-17-2015, 01:08 AM   #16
Dan, is that your garage? If so, where did you get the silver insulation that's on the garage door?
Old 12-17-2015, 06:25 AM   #17
keithmaine's Avatar
Originally Posted by tinman tim View Post
Thanx Spud. Been lurking here for awhile
Rack itself consists of three pieces. A large horizontal 'hoop', and two small 'prop' bars.
Panniers are 18x14x8
As shown above, they're mounted as far forward as possible which requires the stock crash bars to be removed.
Things are still in the proto-type stage for now, but i'm looking for interest/feedback to see if there's a market. As I did the same type set-up for the TW200 community, I'm kinda looking to do it for the Rx3.
That being said, I'm just a guy with a bunch of tools that likes to tinker in the garage.
Question I did have is, does anyone know the load capacity of the stock luggage?
Tim
My Tourfella luggage has a label that says 10Kg and the top box says 5Kg
sounds a little light. The Tusk on my friends KLR650 are the same for the panniers 10Kg each.
hope it helps good luck
Old 12-17-2015, 09:07 AM   #18
DanKearney   DanKearney is offline
Had I not already purchased the Tourfella panniers, I'd certainly be interested in a set-up that provides the same functionality as the Tourfellas, but at a lower price.
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 12-17-2015, 09:40 AM   #19
keithmaine's Avatar
Originally Posted by AZRider View Post
I like these panniers and would be in the market for a set. My question would be how many riders need that much capacity. Most seem to use the RX-3 for off-roading where weight is a factor. My use would be for back road touring and camping and for that they would be ideal.
The size is why I went with the Tourfellas, and for that reason I do a lot of motorcycle camping. This compact ADV Touring bike I believe will be just the ticket for all my up coming adventures.
Old 12-17-2015, 11:49 AM   #20
Rich+PRCBike   Rich+PRCBike is offline
I've seen this before, he attached expanded polystyrene boards with a reflective side inward. Really helps if you have a radiative heater in the garage, reflecting heat back at you.
http://www.lowes.com/pd_41505-46086-...sulation+board
Old 12-17-2015, 12:02 PM   #21
Danimal   Danimal is offline
Banned
That is Tinman's garage.
Old 12-17-2015, 01:10 PM   #22
Thanks!
Old 12-17-2015, 02:22 PM   #23
Thanks!
My brother has those panels on his garage door; they're great.
Old 12-17-2015, 11:02 PM   #24
AZRider   AZRider is offline
Originally Posted by Danimal View Post
They may be lighter than the stock plastic
Danimal, I don't disagree. I was pointing out that the increased capacity would allow for a greater weight to be loaded on the bike.
George
2016 CanAm Spyder F3-L
Old 12-18-2015, 04:27 AM   #25
MauiMikey   MauiMikey is offline
Looks like some nice craftsmanship went into those panniers. Any thoughts to making a larger topcase as well? That would be of more interest to me than larger panniers.
Old 12-18-2015, 05:09 AM   #26
A lot of us like the large, JC Whitney/Garage Pro Travel Trunks.
This travel trunk locks to the luggage rack with a metal mounting plate, and is easily removed when desired. Also, you can't beat the price. I paid $36, delivered, for my last travel trunk.
Old 12-21-2015, 05:28 PM   #27
mouradjan   mouradjan is offline
A friend has made a plastic welding for his RX3 top case.He said it cost him about 20 dollars .He says he did it for his helmet. As u know original case is too small for a helmet. I am not looking for a bigger case but may be this can give a good idea who are interested in.May be it will work better for side cases. I think it will look better.☺.
Old 12-21-2015, 06:24 PM   #28
rtking   rtking is offline
Wow - that looks good! It keeps the original lines, but deep enough for a helmet and maybe jacket? I have to admit that I'm tempted to add a helmet lock somewhere on the bike because I can't put my helmet away. But either the plastic-welded box or Spud's JC Whitney box would work nicely.
Old 12-21-2015, 07:45 PM   #29
That's a beautiful job. How much did it cost?
I do like the fact I can quickly remove the J.C. Whitney travel trunk whenever I please.
Old 12-31-2015, 10:06 PM   #30
tinman tim   tinman tim is offline
tinman tim's Avatar
Originally Posted by RedHawk47 View Post
Tim,
It looks like you have all of the right tools for this project.
I would like a tool box like this that fits the Tourfella racks. It would need clearance for the pannier mounting system:
http://www.advdesigns.com/rurelotoforb1.html
Thanks,
If you can measure and sketch out what you want, I'm sure I can fab it up.
