#16 | |
So.... Today as I was poking around I took a look at the starter/kill switch housing on the handle bar. It was definitely loose. I was able rock it back and forth on the bar about 1/4 to 1/2 inch either way. So I tightened that bad boy up to where it wont move any more.. Then I noticed the front brake line housing tube was loose as well. it rocked from side to side pretty easily. The screw holding it to the back of the starter switch housing was screwed all the way in but the base of the tube where the screw goes in was at an angle preventing it from being flush with the housing. I backed the screw out and straightened up the brake line tube and screwed it back together tight. I am wondering if the loose kill switch housing was causing my bike to die? I don't really know.. I'll have to ride around for another week or so and see if there are any differences. I am going to take a look at the ignition tomorrow and see if there is any corrosion or loose wires that may be causing a short like some of you have stated may be the issue. |
#17 |
Here are some more ideas.
