Old 09-01-2015, 11:51 PM   #16
I suspect that there could be a more aggressive timing curve that will tolerate pump gas, but I'm not sure what that is. If I knew what the base timing and total timing figures were, I could hazard a guess.
I would be interested in trying the USB version, if the software was in English.
I had tremendous success in re-curving a SBC distributor, and power and economy improved. Range for the small tank in the car went from about 150 miles to 240.
Old 03-20-2016, 11:08 AM   #17
79elco   79elco is offline
Stator adjustable.
I have seen on other Honda bikes the stator is slotted so you can move it and change the ignition timing. Has anyone seen this? I also have seen the stator pickup bracket modified with slots to change the timing? The Honda cr125 has a slotted stator. Does anyone have any luck with 93 octane unleaded? Can anyone post a picture of the hawk with the left side cover removed?
Old 03-20-2016, 08:47 PM   #18
humanbeing's Avatar
Originally Posted by 79elco View Post
I have seen on other Honda bikes the stator is slotted so you can move it and change the ignition timing...
What's inside a "CG"...
http://translate.google.com/translat...365&edit-text=
