Old 05-16-2015, 07:25 PM   #16
oldqwerty   oldqwerty is offline
I'm sure both you, and Veteran can hermetically seal this unit.
I sent an email to the vendor, but I don't expect a reply until Monday. The shipping weight for each unit is only 3.5 ounces, so I think the individual shipping cost on ten, or more units should be pretty reasonable. Then, of course, one would need to add the cost of shipping each unit to the individual buyers. However, the SpeedoDRD unit costs $70, and I'm sure the final, delivered cost of this item will be much less than that. I would guess the final, delivered cost of this unit would be $35, or less.
I'm in at 35 delivered.
Given enough of the right kind of sealant, anything can be waterproofed. Watch these Jeeps hit Sippy Hole and imagine what it takes to waterproof a Jeep ignition.
"Thou shall not Zong" is not a commandment.
Old 05-16-2015, 08:06 PM   #17
That makes the total at least six; I might get two.
I don't plan to make any money on this venture. As soon as I get a firm price from the vendor, I will post the delivered cost per unit to the United States. At that time I will accept payment via PayPal before I order the units.
After the units arrive, I will determine the domestic shipping cost via first class mail from the U.S. Postal Service. Then I will ship the units out individually as I receive payment via PayPal for the domestic shipping cost. I might add one dollar per unit to help cover my fuel expenses traveling back and forth to the post office. I don't want to lose money on this deal.
Old 05-16-2015, 08:30 PM   #18
fishman10's Avatar
I'm in too ,Spud!
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 05-16-2015, 08:32 PM   #19
Good for you, Fish.
Old 05-16-2015, 08:34 PM   #20
Of course, if the price isn't significantly more expensive making an individual order, I will let you know. I will only arrange a group buy if the cost per unit is significantly better than ordering the units individually.
Old 05-16-2015, 10:22 PM   #21
Originally Posted by 3banger View Post
I'm in.
Have we ever confirmed how this will also effect the odometer? I know it sounds like an obvious yes. But on my Triumph Sprint ST the speedo reads 5% fast confirmed with GPS but odometer is almost dead-on with GPS data. The speedo error is therefor programmed in on purpose.
I just completed a 12-mile ride across town for groceries. I mounted my Garmin GPS receiver, and recorded the odometer setting. Then I zeroed the trip odometer on the RX3 before departing.
I don't know the accuracy of a GPS odometer. However, here are the results.
Trip distance recorded by Garmin GPS receiver: 12.1 miles
Trip distance recorded by Zongshen RX3 odometer: 12.8 miles
My Garmin GPS receiver records hundredths of a mile, while the RX3 odometer only records tenths of a mile. Therefore, I don't know how close the stock odometer was to reaching 12.9 miles. However, using the most conservative estimate of 12.80 miles, I performed the following calculations.
12.8 miles minus 12.1 miles = 0.7 miles 'optimistic' on the odometer
(0.7 miles divided by 12.1 miles) x 100 = 6 percent 'optimistic'
Using the same, Garmin GPS receiver for comparison, the stock speedometer is running over 10 percent 'optimistic.'
Old 05-16-2015, 10:25 PM   #22
As for myself, I would rather have speedometer accuracy over odometer accuracy. However, everyone must make his own decision regarding this matter. Of course, one could set the Jaycar Speedo Corrector somewhere in the middle, and he would have a 5 percent 'optimistic' speedometer, and a perfectly accurate odometer.
Of course, I am assuming my measurements are correct. I heartily encourage others to complete the same experiments, and report their results.
Old 05-16-2015, 11:14 PM   #23
Veteran   Veteran is offline
Veteran's Avatar
Speedo correction
Duly noted, Veteran. The next cheapest alternative is the SpeedoDRD from 12oClockLabs for $70, and I think this unit is much better protected, and much easier to calibrate.
Maybe a sailor should pay more attention to detail; I didn't see where it said not to get it wet. While I appreciate the vote of confidence in my ability to waterproof this thing; now that I know it's a water-sensitive item, I think I'm going to have to retract my request to be put on the list for them. I can live with thinking I'm faster than I am if it's not fairly bulletproof out of the box.
Sorry Spud, and sorry for the double post; I haven't a clue how that happened.
Old 05-16-2015, 11:21 PM   #24
No problem, Veteran. I understand your concern, and you are off the list.
Incidentally, I don't see a double post. However, if I do find it, I can delete it for you.
Old 05-16-2015, 11:37 PM   #25
I am going to send another email to the vendor of the Jaycar Speedo Corrector, and ask him if the caveat regarding moisture is a CYA (cover your backside) 'warning,' or if the unit is truly susceptible to water damage.
Old 05-16-2015, 11:39 PM   #26
woodlandsprite's Avatar
Thanks for doing that spud! It would definitely be more desirable if there isn't a significant moisture concern
Old 05-16-2015, 11:51 PM   #27
You're welcome.
I just sent another email to Jaycar. Here is the content of the email. I will post his reply as soon as I receive it.
Dear Sir,
I am attempting to put together a group purchase of your Jarcar Speedo Correctors from the United States. However, several people have expressed concerns regarding your statement in the User Manual which says, "never get any part of the module wet." Is this unit water resistant, or is it easily damaged by moisture? Can it be used reliably for motorcycle installations? Thank you.
Old 05-17-2015, 07:58 AM   #28
Huck369   Huck369 is offline
Huck369's Avatar
I'm in for the group buy.....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 05-17-2015, 09:15 AM   #29
Thanks, Huck. We're half way there; I will probably get two.
Old 05-17-2015, 11:19 AM   #30
jimjr21   jimjr21 is offline
I am in for 2 minimum. Have to talk to the other local owners. Maybe 4.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
