Old 11-09-2014, 07:51 PM   #16
katoranger's Avatar
I believe the rear is a 6.25 to 1 ratio. I turn one wheel and the shaft turned about 6.25 times.
Old 11-09-2014, 09:48 PM   #17
katoranger's Avatar
Probably need to multiply by 2 for the open diff. 12.5/1 that sounds more like a golf car ratio.
I think the stock electric motor turned about 3000 rpm. Not sure how much those hydro motors turn. Likely not much. I with need to setup a jackshaft.
Old 11-09-2014, 10:11 PM   #18
katoranger's Avatar
Hydraulic wheel motors are only good for about 200 rpm. I would need a very large sprocket. The little ones on the reels turn faster, but I don't know if the torque is there.
Another option is to remove the golf car rear end and mount the wheel motors to the rear. I think I would find some larger diameter wheels and tires to increase the top speed. The specs for the jacobsen mower said 6.6 mph top speed. This is on 18" tires.
Best option may be to find a faster spinning motor.
Old 11-10-2014, 11:27 AM   #19
I wonder if you can sell the motor.
Old 11-10-2014, 10:07 PM   #20
katoranger's Avatar
Its in the parts pile. Not sure of the condition. Might be a good core.
Old 11-16-2014, 05:40 PM   #21
katoranger's Avatar
The new plan is to remove the rear axle assembly and use the whole jacobsen mower drive motor assembly on the back without suspension. Will use larger tires to get more speed.
Old 11-16-2014, 11:39 PM   #22
I'll certainly follow that build.
Old 11-17-2014, 12:58 AM   #23
X2.
Old 11-17-2014, 09:31 AM   #24
katoranger's Avatar
We are suppose to warm back up this weekend. Axle swapping may start.
Old 12-20-2014, 08:56 PM   #25
katoranger's Avatar
We made a little progress this afternoon. The jacobsen reel mower was cut in half so that the section with the engine and pump could be moved inside. Tomorrow I plan to cut the drive section off and move it inside.
I volunteered to help teach small engines for the 4-H clubs. We may be able to pull this off before fair time.
Old 12-20-2014, 08:58 PM   #26
katoranger's Avatar
Emilie was making our to-do list in the second picture. We changed oil on the big gulp and cleaned it out for our Christmas trip. Filled up with $2.09 gas.
Old 12-20-2014, 09:07 PM   #27
I wondered what Emilie was up to.
Old 12-20-2014, 09:09 PM   #28
katoranger's Avatar
Notice Buford was telling her to buy cat food. This must have been before we used the vacuum.
Old 12-20-2014, 09:59 PM   #29
katoranger's Avatar
This is what we are using for the donar. I bought two from the local golf course in July.
Old 12-20-2014, 10:04 PM   #30
katoranger's Avatar
Dad got the hydraulics off one for his custom cub cadet project. I plan to try and use as much of the mower hydraulics as possible. There is already a cylinder to run a dump box and a 3 point type lift.
