Old 08-03-2014, 04:30 AM   #16
humanbeing's Avatar
...I hope some of the others have 8 wires of different colors...
Vinyl Tape works good in marking the difference.
Qualified sparky in China always stocks these color http://item.taobao.com/item.htm?id=15260137841 | http://item.taobao.com/item.htm?id=36602654320
I "borrowed" the whole color collection from my contractor uncle when doing improvement project in the ancestral house. ***second great grandpa was in OZ during gold rush & made some fortune to built it.
off topic:
In theory , it's as national standard BUT many are wired as "old" British in my home county.
http://en.wikipedia.org/wiki/Three-p...er#Color_codes
Old 08-03-2014, 04:05 PM   #17
Does the headlight come on without the engine running in any of your bikes?
Yes, the headlight illuminates when the ignition key is activated for both my Zongshen 200GY-2, and my Honda XR650L. The Zong employs an AC-CDI unit, and the XR650L employs a DC-CDI unit.
My CRF250X had a lighting coil for an AC headlight, but I converted my CRF250X to a pure DC system using a Trail Tech stator and regulator/rectifier.
http://www.rockymountainatvmc.com/p/...0tech%20stator
The CRF250X has an AC-CDI unit.
The DC-CDI units for the Honda XR650L are notorious for failure. These CDI units become noticeably hot during operation. The solder joints on the printed circuit board of this DC-CDI deteriorate, and fail. Most people suspect the thermal cycling of the internal transformer is responsible for the ruined solder joints.
Old 08-03-2014, 04:17 PM   #18
Interesting.
My Lifan will run the headlight with the engine off, but my TW will not, nor will my old TS Suzukis.
Old 08-03-2014, 04:26 PM   #19
Interesting.
The two-stokes bikes usually don't have a battery. They employ a kick starter, and use an AC lighting coil on the stator to illuminate the headlight. Therefore, the engine must be running, and the flywheel turning, before the lighting coil generates AC electricity for the headlight.
What model year is your TW200? It must have a lighting coil. If so, you will convert your TW200 to a pure DC system if you install the Zongshen stator. The Zongshen system will generate more power to charge your battery, and will give you a nice, steady headlight at all rpms.
However, you will probably need to install a larger regulator/rectifier. I suggest you get the unit employed by my Zongshen 200GY-2. You will also need to connect your headlight to a keyed power line which is connected to the battery.
Old 08-03-2014, 04:37 PM   #20
All three of my old TS Suzukis are factory dual sport bikes, so they're all equipped with batteries.
My TW is a '93, and it was built before the introduction of the more powerful stator. I might upgrade eventually. If I do, I'll change to all Zong.
Old 08-03-2014, 04:41 PM   #21
All three of my old TS Suzukis are factory dual sport bikes, so they're all equipped with batteries...
That's interesting. The Honda CRF250X is similar. It has a battery for an electric starter, but it still employs an AC lighting coil for the headlight. I'm much happier after I converted my CRF250X to a pure DC system.
...My TW is a '93, and it was built before the introduction of the more powerful stator. I might upgrade eventually. If I do, I'll change to all Zong.
You can't go wrong if you go all Zong.
Old 08-03-2014, 04:48 PM   #22
off topic:
Thanks for reminding me about the vinyl tape, HumanBeing.
Old 08-10-2014, 09:26 AM   #23
humanbeing's Avatar
Below maybe the right connector:
Chinese: DJ7081Y-2.3-21 http://item.taobao.com/item.htm?id=39109777167
Furukawa https://www.furukawa.co.jp/tukuru/pd...pcon_01rfw.pdf
Old 08-10-2014, 12:19 PM   #24
Indeed, that appears to be the correct connector! Thank you, HumanBeing.
Old 03-26-2018, 05:11 PM   #25
gilben91   gilben91 is offline
Zongshen wiring harness
Anyone have any clue where i'd be able to get a proper wiring harness for the 2006 zongshen ZS200GY desert fox. i've looked everywhere but it seems like the only part i cant find.
Old 03-27-2018, 10:41 AM   #26
Welcome! Thanks for joining us. I recommend Taobao, since I've purchased several parts there for the ZS200GY, although not for a few years.
Old 03-27-2018, 11:53 AM   #27
humanbeing's Avatar
Welcome! Thanks for joining us. I recommend Taobao...
Keywords: 电缆 沙漠飞狐
Old 09-13-2019, 08:20 PM   #28
Whitapple1   Whitapple1 is offline
Do you know if the CDI units are still available from Taobao? I looked at their website and entered the part number in the search box but didnt find anything. Anyone in the US selling these units? I have a 2006 200 GY tht has a failed cdi unit.
Old 09-13-2019, 08:32 PM   #29
NzBrakelathes's Avatar
I might be able to help but I am a seller etc.
Old 09-14-2019, 06:17 AM   #30
humanbeing's Avatar
Do you know if the CDI units are still available from Taobao...
Use image search
[Hints]
Item #: 39214124554 [交流CDI] / Agent: sup**buy / shipping method: EUB (known as ePacket in proper English)
