#16 |
ITS ALIVE!!!
Bike is back up and running, rode around for about an hr, Speedo stopped working about halfway through, hopefully its just the cable and not that i put it back together wrong. Really need to get the forks straightened out as im pretty much turning right to go straight. |
#17 |
You can straighten your forks using the following method.
![]() 1) While mounted on the bike, place the left side of the front wheel against a wall, tree, or some other solid object. 2) Push the handlebars firmly to the left, and repeat this process until the wheel straightens out.
#18 |
I agree, that usually does the trick. If it doesn't, you can loosen the triple clamp pinch bolts and repeat the process. Don't loosen them much, just take some of the tension off.
