#16 | |
https://www.superbrightleds.com/more...asher/787/842/ http://www.rockymountainatvmc.com/p/...y?term=flasher I installed a DRC Edge 2 Tail Light on my Zong. ![]() http://www.chinariders.net/showthread.php?t=4765
#17 |
some auto parts stores have a small mc section and sell mc suitable LED flashers, given that it is popular to do that conversion. they are clearly marked as being suited for motorcycles.
i wouldn t muck around with car flashers :-)
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS ![]() |
#18 |
I seem to be causing more trouble than I had originally. I've got what I need but I had to do some trial/error with the wiring because the colors are off. The bike has green w/ yellow stripe, green and brown; my new light has brown black and red. While messing with it a couple wires touched and now the bike only kick starts and no lights work at all until the bike is running. I can't find the fuse supply. Please help.
#19 | |
If your brake light only has two wires, it doesn't have a tail light. If this is the case, the red wire is probably positive, and the black wire is ground. Hook your tail light up to a battery to confirm this wiring. You probably shorted the tail light wires, and blew the bike's fuse. The fuse is located on the right side of the bike, inside a hinged, white container which is located above the CDI unit. ![]()
