Old 11-27-2013, 06:25 PM   #16
overlander   overlander is offline
overlander's Avatar
that's a bugger! I've ordered a 42mm pod filter.
The guys from Kustom Kommune thought I could just get bigger jets for the current carby, like what they did with the ace125 ooracing kits
Old 11-27-2013, 07:24 PM   #17
zingshoen   zingshoen is offline
zingshoen's Avatar
maybe they know where?
otherwise, given that u do some mods anyway, the mikuni isn t very expensive, you can get it for 80 aussie dollars from xmoto,
http://xmotos.com.au/
you also may need an intake (bolt on on both sides) as well. space maybe an issue, but one could measure or find out from a raptor mod page?
the jets for the mikuni u can order from ian williams motorsport in south australia, he s got all sizes under the sun:
http://www.ianwilliamstuning.com.au/mikunipartsjets/
last time i spoke to him he said he doesn t deal in keihin parts
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 11-27-2013, 07:45 PM   #18
stellio78   stellio78 is offline
stellio78's Avatar
The 42mm pod filter is the correct size for the stock carb, 42mm is the outside diameter of the intake side.
As for ooracing have you emailed to ask?
What about drilling the jets, is that a bad option if replacement jets cannot be found for the stock carb?
Old 11-27-2013, 08:04 PM   #19
overlander's Avatar
yes, ooracing have been contacted, have to just remove jets and send them photo
Old 11-27-2013, 08:06 PM   #20
stellio78's Avatar
Can you upload the photo here so I can see what they look like?
Maybe these guys could help if ooracing is a dead end http://www.skyteamparts.com/
Old 11-27-2013, 11:58 PM   #21
You can certainly drill out the main jet with a numbered drill bit set, but not the slow jet. Bits don't come that small.
Old 11-28-2013, 12:01 AM   #22
This 30mm Mikuni is only 44 Australian dollars, and the shipping is free. I've purchased several of these.
http://www.ebay.com/itm/Carburetor-C...fd12e4&vxp=mtr
Old 11-28-2013, 03:49 AM   #23
overlander's Avatar
"This 30mm Mikuni is only 44 Australian dollars, and the shipping is free. I've purchased several of these."
So the jet's in these will be fine as is with a new air pod filter and exhaust?
Gentlemen, today I put the Black Wombat back together
Behold the Black Wombat!
China Quality, Brazilian Ass!
We removed the granny Knickers
and put on a form hugging g-string.
And boy does she holler!!
Old 11-28-2013, 04:09 AM   #24
zingshoen's Avatar
she s looking good! you could also wrap the header pipe and of course you ll still need the apehangers :-) can i have a close up of the middle section, where you took off the side covers?
the mikuni will probably come with jets a bit smaller than what you want, but changing them is easy.
Old 11-28-2013, 04:14 AM   #25
zingshoen's Avatar
oh, and a beefy aluminium bashplate would look good.
and ok, maybe not apehangers, just sth slightly higher? to give you even more of that contemporary scrambler look.
https://en.wikipedia.org/wiki/Ducati_Scrambler
Old 11-28-2013, 04:16 AM   #26
overlander's Avatar
sorry haven't really got a close up of the middle section. Leaving one side cover on on the exhaust side ( to hide electronics) and leaving the other off ( to show off rear shock)
Old 11-28-2013, 04:26 AM   #27
zingshoen's Avatar
no worries, some other time! :-)
Old 11-28-2013, 04:51 AM   #28
stellio78's Avatar
Nice work, looks a tone better then stock
Old 11-28-2013, 05:11 AM   #29
overlander's Avatar
now it sounds like a bike! https://www.facebook.com/photo.php?v...84806957&saved
Old 11-28-2013, 10:04 AM   #30
Agreed. The Mikuni will likely have a 100 main and 20 slow jet, and it'll wake up with a 115 main and 30 slow jet, if you're near sea level. Jets are as close as your local Yamaha dealer.
australia, custom, skyteam, v-raptor, v-retro
