01-16-2007, 09:31 AM | #16 |
So there is no need to adjust it ever??
What about the valves??
01-16-2007, 09:39 AM | #17 |
Sounds like it doesn't need adjustment. The valve adjustment is in the manual that came with the bike. Set engine to TDC, then set valve lash. I am assuming the valves are lashed with the engine cold. Of course the manual that came with my bike was for the pushrod engine, but I assume the valve lash would be the same for the OHC.
01-18-2007, 06:58 AM | #18 |
Hi All
Valve adjustment is on a cold engine at TDC, both intake and exhaust valves should be set at .002-.003 thousandths. Ride Wild and Fly Like an Eagle! 8O Bruce
01-18-2007, 08:41 AM | #19 |
Thanks Bruce! Is it better to have these OHC engines closer to .003 than to .002 ? Something I remember reading about them working there way closed or something.
01-18-2007, 09:37 AM | #20 |
Hi Guys
Adjust them between .002-.003 and you'll be Ok. This goes both of these engines, Push-rod & OHC {Over Head Cam}. Valves wear and so do the seats this is why they need to be adjusted. I tighten then at a tight .003. Ride Wild and Fly Like an Eagle! 8O Bruce
