06-28-2013, 02:20 AM | #16 |
I'll take you up on that! I'd be staying two blocks from that new Target.
06-28-2013, 02:24 AM | #17 |
I like your Son of Recracer reference.
I figured that if I ever got ahold of a GL1200, I'd mount an external alternator as well. What type did you use? It looks like a Denso.
06-28-2013, 07:06 AM | #18 | |
06-28-2013, 09:42 AM | #19 |
Im too chicken to do that speed on 2 wheels...thats why i got a dual sport...LOL i would kill myself on anything faster....LOL i keep the speeding to in my truck, where theres at peast a chance of walkig away from a 120mph crash LOL
06-28-2013, 11:11 AM | #20 | |
Did you do any math to arrive at the overdriven ratio? Perhaps you could get the alternator to wake up at a lower rpm. At what rpm does the bike idle?
06-28-2013, 04:42 PM | #21 |
I really Did not put any math to it. Those useing the poorboy kit had similar results . It was way back i did this install ,somewhere in the back of my head the crank pulley is just over 2 times the alternator pulley dia. 5-5 1/4 inches . On a car the crank pulley would likely be at least 7 inches . but there are space restaints on the bike ,the bigger the crank pulley the more you would have to move the radiator at the bottom . i am a bit futher out than the poorboy kit . i will have to check again ,i just remembered the factory volt gauge reads low compared to a meter . 1000rpm +-100 specs. I have it set at 1200 . After i check at the battery maybe i can lower it .
07-01-2013, 11:50 AM | #22 |
I checked it is fine at the battery . Interesting thing owner's manual says if the volt gauge drops below 10v check for a problem .
07-02-2013, 11:18 AM | #23 |
What does the alternator put out at 1200 rpm? Do you have to rev the motor to excite the alternator?
07-02-2013, 09:50 PM | #24 |
Weld i don't have to rev it up ,charging seems to start right away . But also a cold start ,it may idle at 1800 or 1900 and tapers as it warms up.(love that fuel injection) I am going to put up pictures to show rpm and bike gauge and multimeter charge rates . Seems it charges enough to maintain the battery ,of course these pictures are with all the lights on . The wing does not give you a choice ,all the lights burn when its on or running. I am not super concerned about the idle charge if it dips a bit . I found out over the weekend ,if i am out on a ride with the wing ,i may see 1% idle time 99% rolling. That said , i still may replace everything i can with LED bulbs.
07-02-2013, 10:00 PM | #25 |
Other Features of the limited . The alternator is wired one 8Ga wire straight to a 50amp breaker on the battery . Also the grandchildren .
07-03-2013, 08:15 AM | #26 |
So many cool toys.
07-03-2013, 10:52 AM | #27 |
It looks like you've got a winner. It definitely doesn't wake up until 1200rpm, but you won't idle much, just as you say.
Beautiful grandkids! I bet they love riding on the 'Wing.
07-12-2013, 05:49 PM | #28 |
I am getting better at the Stopping and getting feet down and a bit more comfortable working with the weight . The more I ride it the better I like It . Well loving it really .
07-12-2013, 09:24 PM | #29 |
I am impressed by your bike, and your mechanical abilities, and your thrift.
Heck, ONLY 800 lbs??? Try an 1850cc Six cylinder. With the tank full it's 900. Put Linda and I on it and fill the saddlebags with her beauty supply products for a weekend away and we are up to 1,300 lbs. Bike is STILL fast!
Happy to serve. |
07-15-2013, 02:09 PM | #30 |
Thats a bit of a load , i can see how you can get there in a hurry . I had not thought about it , but a full tank and just me would be hauling about 1000lbs and haul it will A few pictures from the weekend
