Old 05-07-2013, 10:28 AM   #16
Thanks! That'll be good info for someone with a ZS250GS down the road.
Old 05-07-2013, 12:48 PM   #17
Corvairkid   Corvairkid is offline
Corvairkid's Avatar
my new break pads just showed up
http://www.ebay.com/itm/180941932124...84.m1439.l2649
looks like a perfect fit
Old 05-07-2013, 02:18 PM   #18
I'm glad you found a CDI unit for your ZS250GS. Please keep us updated concerning how well it works for you.
Old 05-07-2013, 03:24 PM   #19
Corvairkid's Avatar
wiring
hey spud i got a question concerning the green and white wire off the trigger coil if it suppose to go to a common ground string or on its own to the cdi box all the diagrams i found have it going from A to B with out connecting to any other grounds
Old 05-07-2013, 04:55 PM   #20
I can't tell you, Kid. :? The CDI unit for my Zongshen 200GY-2 is an AC-CDI unit, and is wired differently than yours. I suggest you follow the lead coming from the pickup coil, and see where it connects.
Old 05-07-2013, 07:12 PM   #21
Corvairkid's Avatar
i followed both ends and one goes to the ground wiring the other right to the cdi but on both ac and cd the 8 pin skim shows the cdi having its own wires to the cdi no common grounds i was told the ly200 box would work on a 250gs any one tried by chance?
Old 05-07-2013, 08:15 PM   #22
The original, stock CDI unit for my ZS200GY-2 was an LY200 CDI. However, it was an AC-CDI unit. Apparently, the LY200 CDI is available in both AC and DC versions. Here's a link to an LY200 CDI unit I found on Taobao.
http://item.taobao.com/item.htm?spm=...id=20011299305
This is a DC-CDI unit, and it is supposed to work for your ZS250GS motorcycle. You should order the CDI-ZS067-002 shown in the link above.
My ZS200GY-2 motorcycle is now using a CDI-ZS067-001 unit, which is the AC version. I don't know why, but the AC version is over twice as expensive as your DC version. :roll:
Old 05-07-2013, 08:29 PM   #23
Have you confirmed the ZS250GS wiring diagram is correct for your bike? Does you bike employ a DC-CDI unit, as shown in the wiring diagram?
Old 05-07-2013, 08:34 PM   #24
The two wires from the pickup coil connect to two, separate connectors on the wiring harness for my ZS200GY-2 motorcycle. However, these wires disappear into the wiring loom, so I don't know if the ground wire is common. In any event, I don't think it makes any difference; a ground wire is a ground wire.
Old 05-07-2013, 08:36 PM   #25
Corvairkid's Avatar
rut..rooo.....
i keep finding different wiring diagrams for my bike i'm up to 3 now.... but i'm willing to try
Old 05-07-2013, 08:55 PM   #26
Re: rut..rooo.....
Turn on the ignition key, and make sure the engine kill switch is in the "run" position. Get a digital multimeter, and set it to measure 12V DC. Then connect the negative probe of the digital multimeter to ground. One wire at a time, connect the positive probe of the digital multimeter to all of the wires in the harness connecting to the CDI unit. If one of the wires measures 12V+, your ZS250GS has a DC-CDI unit.
Old 05-07-2013, 08:58 PM   #27
Corvairkid's Avatar
and if not...
Old 05-07-2013, 09:16 PM   #28
and if not...
If not, then you have an AC-CDI unit.
Old 05-07-2013, 09:19 PM   #29
Corvairkid's Avatar
*beats his head on the brick wall's of insanity) my battery's dead.............
Old 05-07-2013, 09:21 PM   #30
You've got to replace the battery before you can test the CDI wiring. What size battery is now installed? I would guess a YTZ7S battery will work well in your Zong, if the dimensions are correct.
