Old 08-17-2012, 04:46 PM   #16
450-WheelieBoyz   450-WheelieBoyz is offline
Send a message via MSN to 450-WheelieBoyz
the simplest and cheapest "solution" is to kick start it from now on
and only use the starter on occasion i guess.
i had upgrade the wire gauge, but then it melted and shorted out against the bike frame.
so i put an even bigger gauge wire ( wrapped in an even bigger gauge wire's insulator ) and its not tied down to the frame this time.
hope it doesnt melt ever again.
if it happens one more time im calling my electrician friend and im gonna let him have his way with her.
i guess i cant expect too much from a 500$ dirtbike right?... RIGHT
Old 08-17-2012, 05:19 PM   #17
I guess i cant expect too much from a 500$ dirtbike right?... RIGHT
You can expect it to start and not melt.
Old 08-19-2012, 11:17 AM   #18
so once again my starter is not working...im stripping down the bike next weekend upgrading as much parts as possible. i would really like to re-do the starter ground once and for all.....but how?
hard to kickstart...starter problems.. yayyy ;(
Old 08-19-2012, 11:41 AM   #19
Just curious, are all the other connections clean and tight? A loose connection can cause increased resistance and that can melt a wire as well.
The other thing would be a bad starter like Kato was saying. The bonus there is that the starter for a china bike is a fraction of the cost of a japanese one... I haven't done a search but they should have them on ebay.
Old 08-22-2012, 02:16 PM   #20
its going down this weekend!
changing fuel lines,bolts and nuts,NGK sparkplug, carb cleaning, Loctite everything, and redo the starter ground once and for all !
i will post pictures sometime next week.
cheers
Old 08-27-2012, 04:48 PM   #21
NO F-ING FUEL FILTER! on a brand new x31....
-added a fuel filter
-clear 3/16 gas lines
-ngk spark plug
-good carb cleaning ( dirty jets, debris, NO FUEL FILER :@ )
-Fixed the burnt starter ground ( 10 gauge wire spliced in, added a ground from the battery to the frame ) WOW - what a difference
Anything i forget?
heres some pics, any suggestions would be great. thanks
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
Shot at 2012-08-27
ill will add picture of the new starter ground i did!
cheers!
Old 08-27-2012, 04:59 PM   #22
So that took care of the starter problems? I was guessing it was poor wiring related, my Beast was the same way. Good to see your getting it all sorted out, should be a good bike for you now once you get it all "fine tuned"
Old 08-27-2012, 06:29 PM   #23
katoranger's Avatar
I think you have covered alot of the prep items.
Old 08-27-2012, 09:02 PM   #24
If you remove the fuel petcock, does it have a filter that is inside the tank? Have you set the valves?
Old 08-27-2012, 10:53 PM   #25
amwilkie   amwilkie is offline
I had my wiring harness melt too(I'm pretty sure it was the same wire). I haven't really been on my X31 much due to a surgery. I emailed GIO to see if they will replace the harness.
Old 08-28-2012, 09:42 AM   #26
everything went smoothly, im very pleased XD
all thats left now is fine tuning and esthetics
NO FILTER WHATSOEVER !!
the starter works atleast 10 times better than before. im really amazed
thanks MICRider!
i will be adding pics soon thanks guys
Old 08-28-2012, 11:19 AM   #27
Old 08-28-2012, 12:06 PM   #28
im not very comfortable taking the engine apart/out .... the bike is brand new
cam ajustments is something ive never done. is it really that important right now? i havent even done my first oil change yet.... is there a thread on shimming valves on a Gio x31 ?
thanks weldy
Old 08-28-2012, 12:18 PM   #29
It's a pretty simple process, and it doesn't involve taking the engine apart. It would be good for you to become comfortable with the procedure, because you should at least check your valves every couple of oil changes. If your valves are too tight, they rob power and wear the valves faster. If they're too loose, they also rob power (and they're really noisy).
It sure beats paying someone to do it.
Old 08-28-2012, 12:31 PM   #30
so all i would need is
-valve shims
- magnet
- feeler gauge
-nail polish
if theres a good video on youtube that could help that would be great or a thread please let me know. thanks again
