Old 05-16-2012, 02:45 PM   #16
Frog   Frog is offline
Hi
My GY-5 has the same engine or at least 200cc version (and I think frame by the look of it) - I used an XLR125 header - fits straight on and gets rid of the catalytic converter which is a good thing...
Frog
Old 05-16-2012, 04:14 PM   #17
recracer   recracer is offline
recracer's Avatar
Originally Posted by Frog
Hi
Frog
Good to Know , Just in case this 250 Atc header does not work out , Can you get a measurement center to center of the studs ?
Old 05-17-2012, 04:21 PM   #18
Hi
Frog
Hi just checked - approx 55mm - look like it would not fit your bike :(
Frog
Old 05-24-2012, 12:00 PM   #19
recracer's Avatar
No go on the ATC pipe , once again judging scale in a photo . flange may be fine ,but the pipe is larger scale and double walled . when i get a chance i'll put a comparison photo up . the black pipe is a crf230 pipe i have had for a while . the mounting flange was also to small so i never tried to fit it ,but it is much closer pipe size to the oe 200cc pipe .
Old 06-06-2012, 09:54 PM   #20
recracer's Avatar
The CRF230 front pipe is a pretty good fit . Slotted the mounting flange holes a little . the front of the pipe is a little tight fit in the head ,so sanding was required there . Fitted up the assembly. and will be welding the muffler and pipe . I think it would also be a good upgrade for a 200cc engine ,but you would need to modify the rear section to fit it.
Old 06-07-2012, 01:14 AM   #21
That looks really good!
Old 06-07-2012, 01:48 AM   #22
Indeed! The CRF230 exhaust header looks great!
Old 06-07-2012, 07:13 PM   #23
recracer's Avatar
Heres a look at a flow difference between the headers . the OE 200 pipe a nickle can sit on it without a chance of it falling in . The crf header can fit a quarter with room to spare .
Old 06-08-2012, 12:12 AM   #24
Wow! 8O The CRF header will certainly uncork the exhaust, Ron!
Old 06-08-2012, 11:07 AM   #25
To confirm, can you push anything through the old pipe, or does the cat block the path?
Old 06-08-2012, 09:36 PM   #26
recracer's Avatar
Totally empty . chinese power bomb or EPA fake out . It does not appear that it had ever been cut apart and it only had 700kl on it when i picked it up . i think viva run some though Epa and then cut some cost per bike with a fake cat .
Old 06-08-2012, 10:14 PM   #27
Power bomb sounds better than fake cat. The good news is that you might not need to rejet.
Old 06-09-2012, 12:11 AM   #28
A Chinese, FMF Powerbomb header! I love it!
Old 06-10-2012, 11:58 PM   #29
recracer's Avatar
On the Road again . seems a little louder . jetting seems fine .
Old 06-11-2012, 12:31 AM   #30
The new tailpiece looks great! I like the way the fuel tank graphics compliment the colors of the new tailpiece. The exhaust header and the rest of the bike look great, also. What did you use to paint the exhaust header?
