Old 11-21-2011, 12:38 AM   #16
kevshek   kevshek is offline
will do
Old 11-21-2011, 01:37 PM   #17
Ive checked the carb, both in front and behind, check the inlet manifold which is bolted on tight, i can not see any air leaks or gaps or splits, so im out of ideas.
I managed to get the bike wared up and adjust the idle and slow jet a bit, but when riding, its still running on.
Could this be an electrical issues?
Is this the CDi?
and whats this? rectifier?
Old 11-21-2011, 01:55 PM   #18
Yes and yes. :wink:
Old 11-21-2011, 02:07 PM   #19
Could either one of these give me this running issue?
Old 11-21-2011, 02:17 PM   #20
I don't think so.
I've not read this thread but that sounds like an induction tract air leak to me. Maybe a sticky throttle cablee.
Have you done the starter fluid/ carb cleaner/ propane test?
Old 11-21-2011, 02:21 PM   #21
Nope, what test is that?
Old 11-21-2011, 02:55 PM   #22
Start the bike and warm it up. Get it to idle as stable as it will. Spray the intake boot with starting fluid (my favorite) or carb cleaner or a blast of propane from an unlit hand held torch. If the idle changes, usually faster, you have an air leak. This is very common.
Old 11-21-2011, 03:01 PM   #23
ok, will try that thanks.
so am i just checking from the carb to engine? or do i need to go further towards the airbox?
surely if there was a leak before the carb, it would not effect the carb as that in itself adjusts how much fuel/air goes into the engine.
Old 11-21-2011, 03:04 PM   #24
Correct. Between the carb and the engine. I think this will be your problem.
Old 11-21-2011, 03:10 PM   #25
I agree with Doc.
You can't determine if there is an o-ring problem where the intake tube meets the head, unless you remove the intake tube. That was the very concern with TurboT's atv.
Old 11-21-2011, 03:16 PM   #26
i cant recall if there is a gasket or rubber O ring between the intake manifold and engine, but i know the carb has an O ring to the manifold. Will a paper gasket suffice? thats all ive got to hand to help seal it.
Old 11-21-2011, 10:32 PM   #27
A second o-ring is a better choice, but that's IF the groove is too deep.
Scroll down page four for pics: Fun with TurboT's Gio Beast
Old 11-22-2011, 12:51 AM   #28
ive an idea, i will fill in the groove with some setting gasket sealer or paper gasket, then put the O ring back on top. I dont know what the size of the ring is and dont know where to get one locally.
Old 11-22-2011, 05:09 AM   #29
driller   driller is offline
even a hardware store should have o-rings take the old one with you for the correct size diameter and thickness
Old 11-22-2011, 10:54 AM   #30
Are you in the US, kevshek? If so, you can get a decent o-ring kit from Harbor Freight tools for cheap.
