Old 03-30-2017, 10:29 AM   #16
Originally Posted by JustAdam View Post
So does the blue light operate when the turning signal is engaged or is it on constantly as a running light?
The blue light has its own wire so you could hook it up either way.
2004 Honda ST 1300
Old 03-30-2017, 10:30 AM   #17
Merlin   Merlin is offline
It's intended to be a running light but you can set it up any way you like. Ill set mine up as running lights
Bashan Blaze
Old 04-11-2017, 09:28 PM   #18
Gunrunner Doc   Gunrunner Doc is offline
Ariel, not sure what an "ASIN" is, but it's the closest thing to a serial number I've found: ASIN B0176TA1H4. Otherwise, it's just labeled as "VM26 High Performance Carb" on Amazon.
Old 04-20-2017, 08:00 PM   #19
Another update, couple more parts. And finally calculated my average mpg at 74.6.
Finally got around to getting a Uni pod filter. Couldn't find one that was exactly 42mm, but the 44mm fit just fine. It's a little squished under the plastic body, but it works out just fine. Unfortunately, I'm pretty sure that I need to rejet to a 130 now. As for oil, I just bought the stuff Uni sells on Amazon. I thought I was wasting money on that oil, but turns out that it really does have its own unique consistency. It's more like gear paste in aerosol form.
http://a.co/c6trxrw
New chain, which was much-needed. I wanted to get the one Motocheez did a video on, but they didn't have it on Amazon. Did a little searching and settled on a D.I.D. 428VX x-ring chain. Came with everything I needed, just had to cut a few links out. It came with 130 links, which would probably be fine for you guys who didn't go down much on your rear sprocket, but don't quote me on that.
http://a.co/2orCizR
While I was under there, I noticed that my tire has been rubbing against the muffler of the new exhaust. No damage except for smoother knobs on one side. Moral of the story, if you're going to do the exhaust upgrade, be sure to add washers if you need to for some lateral clearance.
Old 04-20-2017, 08:16 PM   #20
dpl096   dpl096 is offline
dpl096's Avatar
Motocheez is a good guy and damned knowledgeable on the Hawk...actually bikes in general.
― Thomas Jefferson
Old 04-20-2017, 10:22 PM   #21
Ariel Red Hunter's Avatar
I was refering to a model number, such as "VM-26-1076". I'll have to find the book which gives the float height measurements, so that you can check them...ARH
250, haosen, hawk, modifications, upgrades
