Old 11-05-2024, 01:03 PM   #16
onthefly   onthefly is offline
Well crap. Hopefully it's not too long of a wait. I was going to do a Google image search to see about sourcing something in the states, but I gotcha. Let's hope they start stocking these parts stateside
Old 11-05-2024, 07:40 PM   #17
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
Old 11-05-2024, 08:11 PM   #18
GypsyR   GypsyR is offline
GypsyR's Avatar
Is that a "returnless" PWM type pump?
2023 Templar 250 X
Old 11-05-2024, 09:24 PM   #19
No, I don't think it is based upon only being a two wire setup and there is no fuel pressure sensor.
Old 11-06-2024, 12:04 PM   #20
This looks close. It seems to resemble the hawk 250 fuel pump, everything stateside is priced around $120. That being said, if you confirm the pump once you have it removed, I may buy one from Aliexpress just to have on hand.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Old 11-06-2024, 02:58 PM   #21
I thought the pressure sensor is built into the pump, but there's no feedback line (only the two wires for power and ground). There must be a sensor at the throttle body. How would it know when to turn on the fuel pump, or how long to run?
No matter where you go, there you are
Old 11-10-2024, 02:03 PM   #22
misfiring and stalling
I have contacted Zora/Maxpro llc and included the video of the bike misfiring and stalling. I did the engine code test (hold throttle, turn on, drop throttle after the engine light turns on) and I got no flashing code. It doesn't seem to have stored a fault code. That was a cold start. It seems to run OK for a few seconds, then the symptoms begin. Then it happens every time you try to start it, and I had to twist the throttle some (maybe 1/4 throttle or less) to get it to start at all after it ran for 30 seconds or so.
Old 11-10-2024, 05:08 PM   #23
Looks like you'll be replacing your fuel pump too after watching that. You can plug in an OBD-2 reader under the seat to see if there are any stored codes. Mine had a stored code for low battery voltage which was probably the battery being disconnected while running at the factory.
Old 11-11-2024, 06:12 AM   #24
It sounds like changing the fuel pump will be easier than changing a spark plug! I might do both since I will have the tank off.
Old 11-11-2024, 09:11 AM   #25
Between fit/finish and fuel pump issues, i'm wondering if these are redesigned for the US market and truly first run of the model. I recall mention that the Paladin has been sold previously in other countries, and if that were the case i'd think these issues would have surfaced and been addressed by now. Hopefully Xpro/Zumaav can remedy the next batch and we start hearing of less issues and more positive ride reports.
Old 11-11-2024, 09:25 AM   #26
They're sold in other markets with different engines and they are mostly carbureted. The CBS300/NB300 are the most common engine used in the S8 models followed by the ZS172/175 air-cooled engines, the NC250/300/450 seems to be phasing out slowly. The Loncin engines are "rare" in Ukraine and in Russia they're not "officially" released.
Old 11-13-2024, 08:20 AM   #27
Received an ETA from PSM, it's going to be a month. Thumper was told the same. It's disappointing they did not have parts in stock followed by the extremely long wait to get the part.
Old 11-13-2024, 12:25 PM   #28
Ugh that really sucks. Sorry guys :/ Feels like I'm going to be riding on borrowed time. That time frame to receive a part, even if it's coming from China, is unacceptable as well. They must be sending it by boat vs air.
Old 11-13-2024, 01:11 PM   #29
Aussie_in_MO   Aussie_in_MO is offline
would be interested in seeing the pump assembly when it's removed from the tank. I imagine there are plenty of available options for replacement. It's going to be a standard size/form factor pump in a custom(ish) housing that installs in the tank.
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 11-13-2024, 04:21 PM   #30
bigdano711   bigdano711 is offline
bigdano711's Avatar
Tariffs, baby, tariffs. Ever since Trump got elected, maybe a week or two heading up to the election, shipping for simple stuff that used to take 2 maybe 3 days is now taking at least a week. Every nation on earth is indebted to the U.S. for the awesome inventions we've come up with and continue to come up with. The fact that we're in debt to China is ridiculous. I think China is tensing up for tariffs.
2023 Hawk 250 from XPRO off of Amazon
MOUNTAIN MAN RC + MOTO on YouTube
"If there were more bloody noses, there would be less wars." - Hagbard Celine
John 2:15 So He made a whip out of cords and drove all from the temple area, both sheep and cattle; He scattered the coins of the money changers and overturned their tables.
