Old 10-22-2024, 05:02 PM   #16
Do©Hawk   Do©Hawk is offline
Originally Posted by Hebbe View Post
Strings to tie my saddle bag on came untied the other day and got dragged down the road for a little while. Sewed in some nylon with some buckles to make sure it doesn't happen agian.
Consider yourself lucky that all you got was some abrasions on your bags. If those would have gotten into your chain or wheel.......be careful with bags and things that dangle. That could have been much, much worse.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* LED headlight + front turn signals
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
Old 10-22-2024, 07:55 PM   #17
Hebbe   Hebbe is offline
It was tied tight when i left work, sometimes things just happen, its better not to dwell on the little things like that, luck has nothing to do with it if god decided that's how I'm gonna go, well that's just how I go. I came up with a solution and learned from it that's all that matters.
Old 10-31-2024, 01:37 PM   #18
Wife ordered me a set of motocult crashbars, a different luggage rack and aluminum chain covers for our anniversary. So far the magic brown truck has only dropped off the luggage rack.
Old 11-01-2024, 07:39 PM   #19
New aluminum chain guards came in!
ID:	32217   Click image for larger version
Old 11-06-2024, 11:18 AM   #20
got a nail in my back tire leaving work last night so I ordered a kenda heavy duty tube, and since Im already gonna be working right there I went ahead and bought a D.I.D chain and a set of 17/45 sprockets.
Old 11-13-2024, 09:31 AM   #21
Went to harbor freight and bought a stand to work on the bike this weekend. My rear sprocket and chain made it in, still no sign of the tube amazon shows delivery Saturday. Went ahead and ordered an extra for the front and rear so if it happens again I can fix it right away this not being able to ride to work is for the birds!
Old 11-13-2024, 12:42 PM   #22
Got any links to the luggage rack and chain guards? I don't have a luggage rack currently. I just bungee stuff down between the rear grab bars. I don't like the floppy plastic chain guard either....
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 11-13-2024, 01:18 PM   #23
https://www.amazon.com/stores/BAOUFF...CCZBBR2HBTPZAC
I have the csc tubular luggage rack that I took off, you can have for the shipping cost if you wanted it.
Old 11-14-2024, 04:38 PM   #24
Awesome! Thank you, Hebbe. That's the 1st I"ve seen an Amazon store with a collection of Hawk 250 parts.
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 11-16-2024, 06:10 PM   #25
Took the tire and tube up to the local mom and pop Harley shop (shout out jims cycle shop!) I work with through my job and they swapped the tube for free! I also grabbed some amsoil 10-40 to try on my next oil change. After I took the rear sprocket off of the rim I realized that my DLX hawk came with a 45 tooth stock in the rear, the front stock was a 16 I went ahead and put the 17 tooth on the front I can always swap back if I don't like it. Still have to install the new chain and then I'll be back on the road! 15 years working on diesel trucks, I realized I should have been a motorcycle mechanic everything is way lighter!
