09-03-2024, 08:21 AM | #17 |
ATV at work.
09-03-2024, 04:35 PM | #18 |
I priced a CFMoto 500 out the door for $7500 they wanted $7000 for the 400 |
09-03-2024, 04:40 PM | #19 |
I got the hand covers & the back rest but no speakers with mine,I left the hand covers off,did have the back rest on there for a while,kept hitting my leg swinging it over so I took it off.Exact same 4-wheeler I got.I bought a JUST GOING TO SEND IT sticker & stuck it on the front.Mine does have different front headlights now that I look at it.
09-03-2024, 04:59 PM | #20 | |
09-05-2024, 11:16 AM | #21 |
I get mine out everyday whether I'm going to do anything or not.I only run non-alcohol in mine too.Seems that non-alcohol is a little tamer fuel than regular 87 or 93 octane.I don't know what octane it is.$3.79 a gallon for the non-alcohol here where I live.I've had no other problems other than that starter clutch & spark plugs but since I've switch to Champion spark plugs there's no problem there either.
09-05-2024, 11:26 AM | #23 |
That one looking for a transmission,I would definitely open it up & maybe see what's going on,might be a simple fix plus you might can order a gear or whatever from overseas for sure.I broke one of the tabs on my side cover(13/14) when I was fixing the starter clutch so I went ahead and ordered one from Krackow parts in denmark or somewhere.I didn't put it on yet,it stays on there fine with one of the tabs broke but if the other tab breaks it won't so I have a spare.
09-05-2024, 11:30 AM | #24 |
Their in Poland
About Us Our company was founded in January 2017. Mission of our company - to provide a wide choice of original spare parts for motor vehicles. The website krakowparts.com is owned by a company Krakowparts Sp. z o.o. registered in Poland at str. Halicka 10/11 lok. 108, 31-036 Krakow. order.krakowparts@gmail.com |
09-05-2024, 11:32 AM | #25 |
Here's the transmission schematic
09-05-2024, 11:33 AM | #26 |
09-15-2024, 07:55 AM | #27 |
Jerry does yours have the over ride switch on left hand control in front of the light switch.I have no clue to why it's even on there or for that matter if it even works?
09-15-2024, 07:57 AM | #28 | |
I've tried putting the atv in reverse & backing up then hit the override switch but I can't tell if anything happens or not???Maybe use that override switch as a horn switch maybe.European models come with a horn,turn signals. |
09-15-2024, 11:27 AM | #29 |
I never tested it out. Probably could use it for something else more useful.
09-15-2024, 12:51 PM | #30 |
Hi I had a Polaris Trailblazer and overide switch made it possible to give more throttle in reverse.Don't know if yours is the same,but was needed when stuck in the mud.Like to know what it dose on yours. Let us know. Thanks
