05-26-2008, 11:26 PM | #16 |
well i have'nt asked the obvious yet , will it start ?
DesertDog |
05-26-2008, 11:28 PM | #17 |
Sounds like you are on the right track with the new harness. The wire colors and connectors will probably match up.
Allen
05-27-2008, 05:39 AM | #18 |
Have you looked at this site to see if they have your quad parts?
Parts4MotorsportsI havnt bought from this site yet but I noticed they keep adding machines to their list of parts. Maybe email them and attach a picture or two of your quad and tell them what you need. Also give them any numbers off the quad and where they came from on the quad.There should be numbers on the engine and the frame. I have seen those quads around for a while now so getting it straightened out shouldn't be to difficult just a little time consuming. |
05-27-2008, 09:16 AM | #19 |
i bought from them TC , no problems in getting what i needed ,just not soon enough
they did'nt have the quad i have to match the part, but i was able to cross a part off of another quad and it matched right up
DesertDog |
05-27-2008, 03:03 PM | #20 |
look-alike
hey army
you might give these guy's a call they seem to have the exact model you have http://www.motorxtremes.com/adultatvs/index.html scroll down to the 250cc Hurricane , then click video (if you want), but it sure looks the same to me and it wont hurt to ask'em, they like all dealers who have a shop "uhummm" will help ! maybe ?
DesertDog |
05-27-2008, 04:21 PM | #21 |
OMG I see a need.....................
a need for a spell checker................. my spelling has gotten so much worse or maybe I just dont care to proof read it as well. OK sorry back to the subject of getting this quad running thru the woods/trails/prairies/mountains/streams/malls or where ever |
05-27-2008, 05:30 PM | #22 |
no it doesnt start but i do have power to the lights and power to brake lights and i have power to the starter so it cranks but wont start that was with the old harness i dont really have the time to work on it during the week unfortunatly but i will check those sites i really do wish that there was a china dealer in rhode island
05-27-2008, 05:32 PM | #23 |
It sounds like you probably don't have the ignition right then. Check for spark. Also make sure the kill switch is working right. Maybe just disconnect it for testing.
Allen
05-28-2008, 06:33 PM | #24 |
okay so good news its a loncin 250cc engine and the bike is a ata250 everything matches i am just trying to find a wiring harness for it
05-29-2008, 01:21 AM | #25 |
i have been selling kazuma for 5 years.those pic are not a kazuma.
plus kazuma are made in tiwian not china wrong vin for tiwain and kazuma. that a plain jane chinese like bmx,sunl,roketa, i might have a book from a older 05-06 sunl that a customer left. i should have new wire too.
dirty south choppers LLC www.roketaparts.net powersports dealer parts and service www.sunlparts.net kelly stevenson and Gregg martinez sales@sunlparts.net |
05-31-2008, 02:22 PM | #26 |
okay so some people might disagree but today i cut the wires of the connecters on the old wiring harness and then ran all like colors to each other i have lights but no power to the starter and havnt found a way to i am ready to stop and find the correct harness but i am having trouble finding it i am completly lost
05-31-2008, 07:41 PM | #27 |
Do you have power to the solenoid? If so then check to see if the start switch is working. If you don't have one get a voltmeter.
See if you have power to the switch too. Allen
05-31-2008, 08:21 PM | #28 |
i could not post it here so i posted it
HERE http://www.powersportsforums.com/pow...?p=10229#10229 HOPE IT HELPS CLOSEST 200CC WIRES SETUP I COULD FIND IM AT HOME NOT AT MY SHOP.
06-01-2008, 07:29 PM | #29 |
i tried wiring it and no luck i CAN NOT find the wiring diagram for it
5 plug from the left handle bar 4 right handle bar 6 plug cdi 5 plug magneto 6 plug coming from the tranny 5 from rectifier 2 starter solenoid and then the front and rear lights and wires for the radiator i cant find a harness that fits it i cant find a diagram that matches it and i cant hard wire it |
06-04-2008, 05:56 AM | #30 |
maybe you had it but the stator is bad and just needs to be replaced ?
have you found the wire from the stator thats pulses the coil ? It sounds like you can get it to crank over but just not getting the current to drive the ignition circuit. So I would think to start at the source and work thru to the spark plug. Starting at the stator wires find the wire that pulses the the cdi if you dont have that then it wont run as it does the timing for the engine. This might help a little |
