Old 09-30-2024, 12:49 AM   #16
Rujack   Rujack is offline
Ok so I’m back to check on this thread finally.
The manual’s spec for chain slack is 1/2” - 1” on the length below the swing arm WITHOUT the rider on the bike. Which I managed to do by allowing for a little “take-up” after observing the chain tension increase as I tightened the axle nut. Thanks ProDigit for the explanation- I hadn’t realized that was happening.
Another (and previously unmentioned) observation: when rolling the bike, the chain tension will vary from too tight to having acceptable slack, which I believe supports my bent axle (or output shaft) hypothesis. Does it not? I will try to check runout on these tomorrow if I find time.
Old 09-30-2024, 12:56 AM   #17
This and TominMOs response do not adress the fact that OP sez it gets TIGHTER while riding.
Give the OP a break. It is tightening After he thinks he has set the adjusters to the spec (~2 to 2.5cm flex). Some swingarms are broad when loose, they come together pushing the axel back. This could easily result in chain tensioning.
So start LOOSER, and once the axel bolt is tensioned, maybe tension will be OK.
Yes. It seems to be tightening during operation, as I have set it to spec per the manual, however after use it has become too tight.
Old 09-30-2024, 12:59 AM   #18
Originally Posted by bigdano711 View Post
I really like this guy's method. Since I started using the "rag in the chain" method, I've had a MUCH easier time getting my chain adjusted. I also do the adjustment while on the side-stand, so I go for 30-35mm, the upper end of the adjustment range called for on the Hawk 250.
I am using this method as well
Old 09-30-2024, 01:03 AM   #19
[QUOTE=Thumper;412586]
Yes
Old 09-30-2024, 02:57 AM   #20
Thumper   Thumper is online now
Originally Posted by ProDigit View Post
Yeah, my understanding is the same. A chain doesn't keep tightening when riding.
My understanding was that he set the chain up correctly when working on it, and then noticed while riding that it was tight.
Apparently, the claim is that it DOES tighten while riding it. I don't know how that happens. The axel would have to move back. Pushbacks overtightened maybe??? I don't get it.
No matter where you go, there you are
Old 09-30-2024, 08:20 AM   #21
The funny thing is that you can't actually notice that it is tighter while riding it. I mean it is physically impossible
But, I guess that you can observe it getting tighter when your son sits on it
Not true.
I can feel chain tension with my finger when I'm sitting on the bike.
The advantage of a taller person.
Now, I won't do it when I'm riding.
Old 09-30-2024, 08:24 AM   #22
The proper chain slack is 0.25” to tight, when the swingarm is horizontal.
With dirt bikes, a 0.5-1" chain tension is too tight when sitting on it.
It's more like 1-1.25". All you need to look at, is that there's very little play when sitting on the bike, but not so much tension that the suspension can't work properly.
Old 09-30-2024, 11:37 AM   #23
bigdano711   bigdano711 is offline
bigdano711's Avatar
So, I had this issue when I first got my Hawk. It doesn't make sense that it would tighten after riding; figure if anything it would loosen. Turned out to be the crappy stock chain, tight in one spot, loose in another. Have you tried new, decent quality chain?
2023 Hawk 250 from XPRO off of Amazon
MOUNTAIN MAN RC + MOTO on YouTube
"If there were more bloody noses, there would be less wars." - Hagbard Celine
John 2:15 So He made a whip out of cords and drove all from the temple area, both sheep and cattle; He scattered the coins of the money changers and overturned their tables.
Old 09-30-2024, 12:37 PM   #24
I have. I replaced the stock chain with a pro taper.
