Old 12-20-2015, 06:40 PM   #16
Originally Posted by Danimal View Post
just didn't want you thinking I was proposing to anyone that they not oil their filter
I understand. I know you weren't suggesting any such thing.
I'm glad your air filter was oiled, otherwise all that dirt would have gone into the cylinder, and the intake valves would have been damaged. Once again, I encourage everyone to follow Detour's admonition, and check your air filter.
Old 12-21-2015, 10:19 AM   #17
Danimal   Danimal is offline
Banned
I will say this. After cleaning the filter it was obvious that there was very little oil in the foam. It was degreased with only a quarter sized drop of dish soap.
After reoiling and reinstalling there is a noticeable difference. Less intake noise for sure and I swear stronger low end grunt. FYI I left only 4 screws on the hatch. Seems secure enough
Old 12-21-2015, 12:45 PM   #18
Dan, I use that as an opportunity to swap the Philips (or JIS, as the case may be) screws out for stainless socket head cap screws. Much more robust, and allen wrenches are easier to carry on the bike.
Old 12-21-2015, 04:11 PM   #19
As I stated earlier, I use BelRay Air Filter Oil for the flat, foam air filters on my two Zongshen motorcycles. However, I use No-Toil Evolution Air Filter Oil for the conical air filters on my two Honda motorcycles.
The No-Toil system is great, since I can clean the air filters in my kitchen sink, using soap and water. I can avoid using nasty solvents, and the dirty water can be poured down the drain. Once I finish up my bottle of BelRay Air Filter Oil, I think I am going to switch to No-Toil Evolution Air Filter Oil for all my motorcycles.
Old 12-21-2015, 04:16 PM   #20
Old 12-21-2015, 04:21 PM   #21
Instead of using the No-Toil Cleaner, I use an oxygen base cleaner, which I buy at the dollar store.
https://www.dollartree.com/20-Oz-Awe...8832/index.pro
Old 12-21-2015, 04:25 PM   #22
Old 12-21-2015, 05:22 PM   #23
roots   roots is offline
roots's Avatar
Since this is my first bike, I took the opportunity to start fresh and went with the No-Toil oil. There wasn't much oil on my filter, like many are experiencing, which made the switch that much easier, as other oils must be completely removed prior to using No-Toil.
2015 RX-3 Cyclone (Orange)
Old 12-21-2015, 07:39 PM   #24
Good for you. I'm tired of applying sticky, petroleum based oil, and then cleaning my hands with solvent. Even worse, I hate cleaning the goopy filters with solvent, and then disposing of the mess.
Did you choose the original, red No-Toil, or the new, green, No-Toil Evolution?
P.S. Any oxygen based cleaner will remove the No-Toil filter oil. You can buy a pound of oxygen based cleaner at the dollar store, and save about $7/pound, instead of buying the No-Toil Cleaner.
Old 12-21-2015, 10:48 PM   #25
roots's Avatar
Looks like I got the red stuff. I didn't notice the green when I picked it up. Oh well, dries faster at least.
Old 12-22-2015, 01:38 AM   #26
Indeed, the red No-Toil has an alcohol base, and it does dry faster than the green, No-toil Evolution, which has a water base. I use No-Toil Evolution, because my two Honda motorcycles employ conical air filters, which have seams which are joined by glue. Alcohol will destroy the glued seams in conical air filters, which causes the filters to come apart. The alcohol in red No-Toil will also attack the foam in flat air filters, but it is much less of a problem.
Old 12-22-2015, 08:18 AM   #27
Living in an arid climate, the green, No-Toil Evolution filter oil dries pretty quickly. I also own several, spare oil filters. Therefore, I apply oil to all the air filters at the same time, and let them dry overnight. Then I store the extra filters in a zip lock baggy. When I need to change the oil filter, I remove a spare filter from the baggy, and install it in the motorcycle. I usually clean all the dirty air filters at the same time, in my kitchen sink. In fact, you can actually clean your No-Toil air filters in the washing machine.
Old 12-22-2015, 08:28 AM   #28
If you live in a humid climate, the red, No-Toil filter oil will dry much faster. The alcohol will evaporate in about 30 minutes. Even though the alcohol will attack foam filters, your air filters will still last much longer than cleaning them with a harsh solvent, such as gasoline.
Either the red, or the green, No-Toil filter oil will apply much easier than a petroleum filter oil. Therefore, oiling the air filters will be a much faster, easier job. Cleaning your hands is easier. You just wash your hands in the sink with a little bit of oxygen cleaner.
In addition, you will only use about 2 ounces of No-Toil filter oil per filter. Since you can clean the No-Toil filters with any oxygen based cleaner, the No-Toil filter oil is not only easier to apply and clean from oil filters, it is actually less expensive than petroleum, air filter oils.
Old 12-22-2015, 09:36 AM   #29
keithmaine's Avatar
Thanks for info I have never tried no toil but I will now. I have been using the Unifilter cleaner and oil as my other foam filters were all Uni.
Old 12-22-2015, 09:45 AM   #30
You're welcome. Cleaning and oiling air filters are two of the nastiest, messiest jobs of motorcycle maintenance. However, these tasks are also two of the most important jobs in motorcycle maintenance. The No-Toil system makes these tasks quicker, cleaner, easier, and less expensive.
After I use up my remaining bottle of BelRay Air Filter Oil, I am switching exclusively to the No-Toil system.
