12-09-2020, 02:32 PM | #16 | |
12-09-2020, 06:54 PM | #17 |
I drilled and tapped the port 7/16-20 and ran a bolt in. I then blended the end of the bolt to match the inside of the exhaust port
12-09-2020, 07:57 PM | #18 |
Was there any difference in performance after closing off the EGR port?
tom
vertical and above ground - my daily goal |
12-10-2020, 08:56 AM | #20 |
Got in touch with Joe after emailing a few questions. I was happy to hear that the gains from the full head p/p work come to 4hp.. a sweet 26% gain in performance which is pretty amazing. Now just need to find out how long the process will take from when i ship it out to when i have it back in my hands.
12-10-2020, 10:42 AM | #21 | |
12-10-2020, 11:36 AM | #22 |
I realize there would be more noise without the EGR being connected and the passage/port uncovered.
To simplify. Was there significant difference in power output with the EGR passage covered with a plate, and the EGR function disabled? My quick view is that it uses a controlled amount of exhaust gas that is fed to the intake via the air cleaner. I did not dig in deeply to figure the actual inlet used. I guess I could do that, and plug the 'feed' to see if there was a difference, but being a bit lazy, and being chilled outside, asking is quicker, easier, and adequate. tom
12-10-2020, 12:03 PM | #23 |
EGR is just used for emissions, just plug it. It is a way to reburn exhaust gases. If it's actually SAI, aka secondary air injection (which is what I think it actually is), that just takes some air from the atmosphere and adds it to the exhaust, which warms the cat up quicker, but really doesn't make it run any cleaner, except that it dilutes exhaust gases/forces a more complete burn of fuel outside of the combustion chamber. It just looks better to emissions sniffers.
There won't be a noticeable difference to how you do it, just make sure it isn't venting directly to the atmosphere from the cylinder head, because you might burn up a valve. If send the one that doesn't have the casting for the valve, myself, and get it ported, running the one with the blocked off EGR/SAI now. |
12-10-2020, 12:59 PM | #24 | |
I set her to top dead center before doing anything else. I was very careful and used a magnetic telescope wand to make sure that the washers didnt fall anywhere in addition to stuffing paper towels into the holes next to the bolts to be removed. I spoke with Joe this morning and he also told me that he sells a 4 degree flywheel advance key for $22 and im going to buy that as well. He said that while the port and polish adds horsepower, the ignition advance increases torque very a very large amount, so it sounds like a winning proposition to me. Ill just have to buy a flywheel puller and look into that procedure. On a sidenote, on the exhaust manifold there was a ratty piece of metal that i pulled out, i assume it was the leftover of the crush washer, if anyone knows the part # for this it would be appreciated as ill need it for sure.
2024 Zuma Storm 150 DLX 2019 Beta 430 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X Last edited by tknj99; 12-10-2020 at 03:51 PM. |
12-10-2020, 01:03 PM | #25 |
Properly functioning EGR has no effect on performance..as Franque says, its for exhaust system emissions...it takes no power to run it.
That being said, many remove it to clean things up,...looks neater.
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
12-10-2020, 01:52 PM | #26 |
Hard to get good pix of the ports. I used a headlamp to shine around the camera. Exhaust gasket link
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
12-10-2020, 03:03 PM | #27 |
Just mailed the head out to JH. Turn around should be 4 days plus transit time. Very excited for the anticipated results.
12-10-2020, 03:04 PM | #28 | |
12-10-2020, 03:49 PM | #29 |
I also am purchasing his 4 degree timing key. Does anyone have experience with this on a Brozz? Was it an easy install? Do i just need a flywheel puller?
12-10-2020, 03:54 PM | #30 | |
