11-06-2016, 08:32 PM | #16 |
What are you trying to prove? You don't even own both of the carbs in question. I think it best if we both dropped the whole thing.
11-06-2016, 08:35 PM | #17 |
Can I get an Amen?
11-06-2016, 08:47 PM | #18 |
Im just saying what I said from the start before you two jumped in with your nonsense, he does not have to buy that mikuni.
11-06-2016, 08:53 PM | #19 |
Amen brother, you don't even own a chinabike
11-06-2016, 11:30 PM | #20 |
True, but I have owned and tuned Amal, Bing, Delorto, Mikuni, Villiers and Keihan carburetors for over 60 years.
11-07-2016, 12:03 AM | #21 | |
**keihin** |
11-07-2016, 07:42 AM | #22 | |
11-07-2016, 09:07 AM | #23 |
I cut the slots with a fine tooth hack saw. It was a whole lot safer than the dremel.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-07-2016 at 05:37 PM. |
11-07-2016, 10:31 AM | #24 |
The Keihin has 0.8 mm threads. The Mikuni has 0.75 mm threads. That's close but not identical. The Mikuni jets will thread into the Keihin carburetor ok, but the Keihin jets will screw up the threads in the Mikuni carb.
11-07-2016, 10:58 AM | #25 |
got it.
11-07-2016, 05:38 PM | #26 |
Where did you get this information, I would like to read it. everything I have found said the head of the keihin jets are a mm bigger also, these are not. maybe its a china thing and not real brand copy jets. wish I had a metric thread pitch tool....
11-07-2016, 06:11 PM | #27 |
I got this information from Human Being's post # 13 on the "Bashan Blaze can't get past 7000 RPM" thread. Human Being seems to be able to read Chinese. He often posts on electrical problems.
11-07-2016, 06:24 PM | #28 | |
from jets are us OVERALL LENGTH = 9mm HEAD DIAMETER = 8mm THREAD DIAMETER = 4.9mm THREAD PITCH = 5.0 x 0.7 MIKUNI N100.604 and no KEIHIN is the same physical size, so mikuni knock off main jets may be in these stock carbs |
11-07-2016, 06:41 PM | #29 |
My only point was that those Mikuni jets will fit in the stock Hawk carb but not in the Mikuni VM26. I know it because I tried to use them in the Mikuni and they wound not thread in. That is all I have say in the great main jet debate.
11-07-2016, 07:02 PM | #30 |
But now my curiosity is kicked in
