Old 07-23-2020, 08:45 AM   #16
Originally Posted by Its_not_a_honda View Post
Man you guys are lazy. JK. I used to do this back in the 80's. I raced go karts. 5hp briggs. When briggs went to electronic ignition, it didn't take us long to start fiddling with it. I would take some key stock and a file and make my own. THEN I figured out that the flywheel key was only to locate the flywheel. Once the nut was tightened, the key does nothing. The taper fit is what holds it in place. Once you know this, your timing is unlimited. I never ran a key again. Used a degree wheel and timing light. Just letting you guys in on racing secrets.
Yeah, I've done that myself. The key just takes the guess work out of getting the timing dead on. I'll probably just take the spare stock key from my X22R and file the offset in it and install on my Hawk. I like to have the key installed in case of a back fire the flywheel doesn't shift too far out of timing. I've had that happen before.
2004 Honda ST 1300
Old 07-23-2020, 03:10 PM   #17
OneLeggedRider's Avatar
What Jerry said.. ^^^
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 08-03-2020, 12:53 PM   #18
I'm shamelessly bumping this thread back to the top like Tako does, but not for personal gain. I thought you folks would be all over this! To get that much of a performance increase for $18 and a quart of oil, and less than an hour of work?!?!
Old 08-03-2020, 12:58 PM   #19
I'm getting ready to order two. One for the Hawk and one for the future bike. Don't need to convince me. lol
2004 Honda ST 1300
Old 08-05-2020, 03:38 PM   #20
Originally Posted by jeffrey View Post
What are the dementions of the stock fly wheel key length X width.
Length and width for the stock key is 14mm x 4mm and the height of the curve is 4.1mm. The offset for the 4° advance is 0.7mm
So that's simple enough, make your width 4.7mm and then cut the opposite sides halfway through the height to 0.7mm
Old 08-08-2020, 01:05 AM   #21
4x4Dragon   4x4Dragon is offline
+1 for Joe Henner being great to work with! Super responsive and helpful. I've got one of the flywheel keys from him but haven't put it on yet. (i have a Kayo T4) guess i'm still a little intimated in doing it though Joe did send me the link/part number for the correct flywheel puller.
Old 08-08-2020, 11:52 AM   #22
alex_in_az   alex_in_az is offline
which is the correct puller? the one I have has 24mm and 27mm threads on it, but I haven't used it yet
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 08-08-2020, 12:17 PM   #23
Goob   Goob is offline
Joe Henner Youtube?
Originally Posted by RedCrowRides View Post
@TheChairman Contact Joe Henner at his facebook page, Henner motorsports, he is very responsive. he also has a YouTube channel if you want to see his videos about this advanced timing key or the Orion RXB 250 which he has also done extensive mods too, all the mods should also apply to a Brozz, etc.Cams, big bore kits, etc.
How do I find the Joe Henner Youtube channel? Sorry, I a new to Youtube and have yet to figure out how to find specific channels. I have subscribed to several (including JerryHawk250), but can never find the channels again after the first time.
CSC TT250
Orion RXB 150XL
Old 08-08-2020, 09:05 PM   #24
Type in Joe Henner and then subscribe.
Old 08-10-2020, 11:24 AM   #25
not sure if it's exactly the same for your bike but Joe referenced part number: 08-0425 from Motion Pro. (M28 x 1.0)
Old 08-10-2020, 12:17 PM   #26
This is the one you will need. It's the one Megadan used. https://www.ebay.com/itm/1pc-Black-M...72.m2749.l2649
2004 Honda ST 1300
Old 08-13-2020, 09:44 PM   #27
ok, great! next question, which way should the offset key face so I don't retard the timing by 4 degrees?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 08-14-2020, 10:46 AM   #28
Deckard_Cain   Deckard_Cain is offline
Just ordered my flywheel key last night! Shockingly, Joe replied via FB Messenger at like 1230 in the morning, and I was up.
2 mins to paypal some money and boom, done!
Now to get the puller or make one....
Old 08-14-2020, 10:48 AM   #29
The engine rotates counterclockwise looking at it from the flywheel side so Offset will go to the counterclockwise side of the key.
2004 Honda ST 1300
Old 08-14-2020, 10:56 AM   #30
Well this is conflicting ... lol.
The Motion Pro tool is M28.1.0 .... th eone Dan used, that you link here, Jerry, is described on the page as M27x1.0.
Pretty sure one won't work and the other will.
So any ideas all which is correct?
