Old 11-01-2015, 11:44 PM   #16
Cyclone54   Cyclone54 is offline
It looks like the newer headlight would work better with the Cree Speedmetal light that I have because the high beam led points six o'clock straight down on the top of the wanna be projected light. The Canadian version looks like a nicer reflective surface.
Old 11-01-2015, 11:46 PM   #17
Okay, that's great. I think H4 incandescent lights use the top surface of the reflector for high beam.
Old 11-02-2015, 01:11 AM   #18
Lee R   Lee R is offline
Lee R's Avatar
Originally Posted by detours View Post
Yeah, not safe for asphalt, but on the other hand, it might dry out your muddy trails
I had a pair of 3000 lumen LED Aux lights on my Tiger 1050, I had a deer run out in front of me and quickly run from the lights, they were so bright it was painful to look into them.
With the stock lights, 780 lumen aux lights and the 3000 lumen lights it looked like a 747 was about to land on the road
Night or Day wasn't much difference!
Old 11-02-2015, 01:40 AM   #19
Old 12-29-2015, 10:06 PM   #20
detours   detours is offline
detours's Avatar
Anyone who installed a 55/65W halogen in your headlight, check for melting. I just checked mine and found some melting at the top, despite the ventilation hole in the back. You can see the bubbling and browning at the top and some warping (note the rainbow colors) along the back of the reflector.
The 65W high beam is only 3 inches from the top of the assembly. So even with ventilation cut directly behind the that area, it may not be enough to cool it down.
My lamp is a Silverstar Ultra. I love the bright light, but I wonder if it puts out more heat than other halogens.
Red 5 standing by!
2014 Ural Patrol
Old 12-29-2015, 10:11 PM   #21
detours's Avatar
Here's a pic from a new headlight assembly. This is the new Canadian-approved headlight that I plan to test with a new LED in the near future.
Red 5 standing by!
2014 Ural Patrol
Old 12-29-2015, 10:31 PM   #22
I noticed almost identical bubbling/distortion of the headlight reflector after I installed a standard, 55W/60 H4 bulb. However, the bubbling/distortion has not worsened since I cut the ventilation hole in the back of my headlight.
Old 12-29-2015, 10:33 PM   #23
Is the new LED bulb short enough to avoid contacting the bike's frame?
Old 12-29-2015, 10:36 PM   #24
Danimal   Danimal is offline
Banned
I just installed a 3000 lumen 5th Gen Cree in my RX3s shell
Funny thing is, there are two LED emiters on each side, and they are pointed at the sides of the reflector shell, not the top and bottom.
5th Gen have no fan. The chips are bonded directly to a thick copper strip that has copper braids attached. After mounting you splay the braids to increase surface area
Seem bright as hell and well directed. Havent tried them on the road yet though.
and after mounting, spread the braids out to fit in the shell
I know it cant be mounted wrong. The adaptor for H4 only fits one way
and then locked in
Light assembly slides in on an o ring seal and twists to lock.
Old 12-29-2015, 10:44 PM   #25
Adjuster's Avatar
What are the braids for? Heat sink?
Old 12-29-2015, 10:49 PM   #26
detours's Avatar
I just did a test install and it barely clears. It may vibrate against the frame but I haven't ridden with it yet. I'll have pictures of the light pattern shortly.
Red 5 standing by!
2014 Ural Patrol
Old 12-29-2015, 10:50 PM   #27
detours's Avatar
I like the simplicity of this LED. Post pics of the light pattern when you can!
Red 5 standing by!
2014 Ural Patrol
Old 12-29-2015, 11:03 PM   #28
Banned
yes....they say they run cooler than the fan units as well, even when the braids are in an enclosure
Old 12-29-2015, 11:04 PM   #29
Banned
here they are
http://www.ebay.com/itm/5th-Gen-H13-...BVuE46&vxp=mtr
Old 12-29-2015, 11:55 PM   #30
I just installed a 3000 lumen 5th Gen Cree in my RX3s shell...
X2; we eagerly await reports/photos of the light pattern.
