05-29-2019, 08:21 PM | #16 | |
05-29-2019, 09:44 PM | #17 |
I actually just talked to motocheez on IM. He told me to go to a 115 main and two and a half turns on the mixture screw. So ill give that a try. This darn bike is frustrating as hell, at least for me, but its inspiring to see that other people have success with them!
05-30-2019, 04:47 AM | #18 |
Valves
Can you tell me if its ok to adjust the valves when the engine is cold? Right now I dont even want to start it up because it gets so hot. So come to think of it the bike probably needs a valve adjustment. That makes total sense and I should have checked them to begin with.
05-30-2019, 06:00 AM | #19 |
get the motor hot... running temp...
with it idling... turn the mixture screw in or out to get the highest idle speed... then turn it back in 1/8 a turn... then reset the idle on the idle adjuster..."throttle" DONE... the choke looks after the idle on a cold motor... not fiddling with the mixture screw every time you start it... I have not turned the mixture screw on my bike for over 2 years because there is no need to... ..
05-30-2019, 07:30 AM | #20 | |
05-30-2019, 10:49 AM | #21 | |
These might very well make things much easier for you oh abd the tool to adj the carb screw to tube idle jet |
05-30-2019, 10:50 AM | #22 | |
05-30-2019, 11:01 AM | #23 |
Before you go trying to adjust the idle mixture you need to set the valves. I don't have a video on it because it is so well covered already. It is a super easy job to do that doesn't take very long to do.
Motocheez is spot on with the 115 main jet. As far as the idle mixture, with that stock 40 pilot jet, you are going to likely find yourself well past 2 turns out to get the idle right with a pod filter and exhaust. Ideally you will want at least a 45 pilot jet, and even with that you will likely find yourself past 2 turns out - I am at 2 1/4 out with a 45.
05-30-2019, 11:47 AM | #24 | |
Again I would do the valves before anything. |
05-30-2019, 06:37 PM | #26 |
Never a bad idea to take a break and clear your head. It can keep you from making mistakes.
05-30-2019, 08:53 PM | #27 |
You'll get there but don't give up.
05-31-2019, 10:36 AM | #28 |
Btw, does anyone have a pic on how to install a pod filter on the magician?
05-31-2019, 06:40 PM | #29 | |
when the mixture screw is set at maximin vacuum on the emulation tube "long brass tube the main jet screws into" the vacuum can fluctuate with float level changes.... so reducing it slightly helps stop this..... Or something like that.. I got this info from a book on carb tuning I read years ago it seems to work... ..
06-18-2019, 05:40 PM | #30 |
sweet ride!
you said the regulator went bad? what did it do? My Magician just died...total loss of power. =(
