Old 10-25-2019, 08:24 PM   #16
NzBrakelathes's Avatar
Originally Posted by swolff View Post
Its a tt style. Im in Georgia. Dash works fine, just don't want to have to kick the darn thing every time. I dont think its the gear indicator connector. Is there another 6 pin connector?
So far I’m not making sense from what you’ve said etc
I don’t recall selling a Hawk TT cluster but I could be wrong
Gear ind wires are just the earths for the numbers
Things are not adding up for me......
Old 10-26-2019, 12:06 AM   #17
CLICK - I found you!
I am a little confused as to how you have it connected etc? so no Black it turn on? or...?
Unplug the gear ind harness and others as they should - what result?
Or remove the fuse by battery - what is the result?
Or remove the tacho wire - what is the result?
Old 11-01-2019, 09:21 AM   #18
http://chinariders.net/showthread.php?t=24886
Old 01-20-2023, 02:52 PM   #19
Johnetattoo   Johnetattoo is offline
Johnetattoo's Avatar
Igntion switch
I know this is an old thread but maybe someone will need this info someday. It could be the ignition switch. They are junk. Turned completely on nothing works. Turn the key towards the off position slowly until everything comes on. Just replaced my switch and a buddy did his a couple months ago. Same thing.
Only noticed this as I was switching the key off while troubleshooting and saw a flicker on my aftermarket digital speedometer.
Old 07-14-2024, 07:44 AM   #20
jatgm12   jatgm12 is offline
Does anyone have knowledge related to the shark 250 by Bashan? I have replaced the engine with a non-counterbalanced shaft one, and I just matched the colors up, because the engine plug was not on the connectors. There was a pink wire on one and a white wire on another that were the last wires, and I just put them together. Is that correct or did I do it wrong? Does anyone have a wiring harness for the shark 250 or one that would be the same by chance?
