#16 |
ss27gogeta...how do you like your x-pect?
I was on the fence about getting a TT250 or an x-pect. Decided on the TT250, but still like the FI and gas mileage on the x-pect.
How do you like yours? |
#17 | |
#18 | |
When you put the 17t sprocket on was there enough room for an 18t or 19t sprocket. If 17t is good for 55mph at almost wot. An 18t or 19t would probbly be perfect for a sustainable 55mph.
Current Bikes 2019 Lifan Xpect 2016 Harley Davidson Roadster |
#19 |
I'm looking to get a 250L plated in Oregon. I contacted Orion and they say their bikes are EPA compliant, and can get a letter from the manufacturer stating so (a requirement in Oregon). However they said all the Chinese factories are closed currently due to caronavirus. I'm waiting till the factories open back up before I buy, because the entire point of me wanting one of these is for dual sport purposes haha.
Please post of you can get yours registered in CO! |
#20 |
Will Oregon plate bikes classified as 'off road dirt bikes' by the EPA?
#21 | |
Colorado registration
CSC TT250 Orion RXB 150XL |
#22 | |
No not at all, that's the problem. The guys at Orion said it's classified as a motorcycle, not off road. And they have a letter from the manufacturer stating it's epa compliant. But them saying that and having the bike actually registered are different haha, so I'm trying to find if anyone else got it done successfully |
#23 |
That's always my fear for members and I have seen people here on Chinariders getting burnt (fortunately rarely) from time to time, so I do like to bring it up. I do know the Apollo dual sport is EPA/DOT for 49 state legality, but the suspension is heavily biased for the road, whereas the Orion is similar to Pitster Pro/GPX bikes which are primarily dirt bikes that have street equipment.
#24 |
RXB150 Delivered today!
That was fast! Ordered on the 17th.
No damage in the shipment. I thought the MCO would be in with the packaging, as I saw an un-assembled on a youtube that did. I contacted Orion to ask. Drained the shipping oil, put new oil up to the middle of the window, put about 1/2 gal of 91 octane in. Started on the 3rd try. Ran for a bit, until warm. Stopped, waited, checked the oil level, added a bit. I think what I had to add was what filled the oil cooler. It won't settle to idle, so I think I will need to mess with the jets and needle position. I expected some adjustment since I am in Denver. The one thing I don't like is having to pull in on the hand brake, while trying to slightly twist the throttle, and push the starter button. What's the hand brake thing all about! It is stupid. I learned from a young age to pull in the clutch when starting...this leaves your hand free to twist the throttle a bit. Does anyone know where I can jump out the hand brake switch?
#25 |
Try the foot brake instead of the hand brake.
#26 |
Using the foot brake now!
Thanks. JerryHawk250 let me know that too. I still want to find out how to disable this "feature".
The power from the front and rear brake must be paralleled into a relay of some sort and when powered the relay makes the starter circuit. If I can find that location, then I will remove the starter circuit wires and connect them together.
