04-09-2017, 01:08 PM | #16 |
Great job. Thanks for the video Iam sure it will help a lot of people.
04-09-2017, 05:57 PM | #17 |
i did notice you don't have the front brace between the fairing, those rounded hex bolts in the rack will go there...i did the same thing. nice video!
04-13-2017, 12:01 AM | #18 | |
front fork brace
Yes, good callout on the fairing brace. I had that part "left over" after construction, and it was not until after I finished the video that I figured out where it went. I still have not installed it; putting it in place requires pushing out on the fairings some, although it may be designed that way. And you correctly stated the bolts that I used on the luggage rack go there. The other correction I noted after watching the video was i had neglected to put the vent tube on the battery... that has been corrected. Anyhow, looking forward to getting home this weekend and doing some riding. |
