Old 04-09-2017, 08:22 PM   #16
frame
measure the spread left and right side.... the spread should be about the same distance..
ABIBABA ATV ETC
Old 04-11-2017, 07:44 PM   #17
turbofiat124   turbofiat124 is offline
turbofiat124's Avatar
After I put the bike back together, I kept hearing this scrubbing sound when I'd hit bumps but couldn't quite track it down.
So I got to looking and now know where the scrubbing was coming from. The chain is rubbing the frame in this location:
As mentioned before, the rear end wants to squat to the left when I sit on it due to the rear shock absorber I modified from 30 mm to 20 mm eyebolts.
Luckily I finally found a rear shock with 20 mm wide eyebolts. So I'm hoping this will fix the issue with the rear end squatting at an angle.
http://www.ebay.com/itm/281661171925...%3AMEBIDX%3AIT
