07-17-2018, 04:35 PM | #16 | |
Specs of Fbomb have changed slightly over the past weekend. I added both a WD "Blue" series SSD and did a clean install of windows 10 to get rid of some problems. Also installed a WD "Blue" series 2 tb drive that will now act as my main archive. The original 1 TB WD "Black" series will serve as my game drive only from this point. The SSD will contain the OS and a few needed programs only. The saved items from said programs will be saved to the 2 TB Blue drive.
I also picked up an HP Z400 workstation that was delivered today. I will put up a spec sheet on it once i get Speccy on it. Summary Operating System Windows 10 Home 64-bit CPU AMD A8-7600 58 °C Kaveri 28nm Technology RAM 8.00GB Dual-Channel DDR3 @ 930MHz (10-11-10-30) Motherboard ASUSTeK COMPUTER INC. A88XM-A/USB 3.1 (FM2+ ) 37 °C Graphics WXGA TV (1360x768@60Hz) K222HQL (1920x1080@60Hz) 1024MB ATI AMD Radeon R7 Graphics (ASUStek Computer Inc) 5 °C Storage 232GB Western Digital WDC WDS250G2B0A-00SM50 (SATA (SSD)) 33 °C 931GB Western Digital WDC WD1003FZEX-00K3CA0 (SATA ) 32 °C 1863GB Western Digital WDC WD20EZRZ-22Z5HB0 (SATA ) 29 °C 931GB PHD 3.0 Silicon-Power USB Device (USB (SATA) ) 32 °C Optical Drives ASUS DRW-24F1ST c Audio Realtek High Definition Audio Operating System Windows 10 Home 64-bit Also slight change with the planned future build. One i am not getting the AMD Athlon II from my friend as he gave me the 6 core Phenom II he got to replace it instead. Turned out the motherboard in his machine would not recognize all 6 cores. Plus the Ryzen build will not occur now since i got the Z400.
Past bikes: '10 Gio X33 '85 Honda VF750F Interceptor '80 Honda XL185S '76 Yamaha DT250C dual sport Baja Wilderness Trail 250 '07 Honda Shadow 750 Areo Trike '01 Harley Davidson Softail Deuce Polaris Magnum 425 4x4 Quote:
07-17-2018, 04:40 PM | #17 | |
Here is the info on the new to me z400
Summary Operating System Windows 10 Pro 64-bit CPU Intel Xeon W3565 @ 3.20GHz 49 °C Bloomfield 45nm Technology RAM 8.00GB Triple-Channel DDR3 @ 533MHz (7-7-7-20) Motherboard Hewlett-Packard 0B4Ch (CPU0 PROCESSOR) 67 °C Graphics K222HQL (1920x1080@60Hz) WXGA TV (1360x768@60Hz) 1023MB NVIDIA GeForce GT 710 (MSI) 45 °C Storage 298GB Seagate ST3320413CS (SATA ) 30 °C 14GB Kingston DataTraveler 3.0 USB Device (USB ) Optical Drives hp DVDROM DH20N Audio NVIDIA High Definition Audio
07-17-2018, 08:54 PM | #18 |
My son and I built mine.
cheap corsair case and cannot remember power supply AMD 8 core Vishera 8320 3.5 ghz 4- G skill ares 4gb sticks of ram asus 960 mother board strix gforce gtx 960 GPU 1 tb hybrid HD It is not a super fast PC but it runs campaigns for most games on ultra settings OK although as it ages and games get more complex it is showing it's not keeping up as well online. I have 2 extra 4 gb sticks of Gskill ares ram if anyone needs it make me an offer. |
07-18-2018, 11:20 PM | #19 | |
Here are a couple pics of the new to me HP Z400 workstation. It was good timing getting this since it seems i may have an issue with the Ram in the Fbomb machine. Ultimately as much as i dislike saying it i may need to a deeper overhaul of that machine, Two options on that one.. getting a new motherboard for the existing processor and Ram or new motherboard,processor and Ram. However i do have one trick left to try before going to that level and that is changing out the Ram itself to see if i have a bad stick. But for now i will use the Z400 and probably make a couple more changes to it in the form of adding a second HD and a proper wireless adapter to free up the USB port on the back. Will eventually add a USB 3.0 card to it as well for the high speed external drives i have.
