#16 |
For real! Tallboy stroker kit.
#18 |
I ordered one yesterday. I'm looking forward to having real chain adjusters lol. Any real need to change the bushings if they are in decent shape? Mine is coming with bushings, chain adjusters, and chain guard for $119.
#19 |
What's it take to do a swingarm swap? Does the grom arm bolt right on??
#20 |
So I'm told. Pretty much all the grom parts bolt right on with a few exceptions. I don't know if the grom swingarm is necessary with these swaps, but it cant hurt. Plus the stock chain adjusters are crappy. I suppose one could pull them out and put measurements on them with a grinder.
#21 | |
#22 | |
#23 |
You need to grind on the frame where the swingarm mounts a tiny bit. As for the rubber bushings. They wear out sooner and I myself didnt want to take arm off again plus they make the bike feel much more solid. I wanted better adjusters without modding the adjuster some they won't fit in the clone arm and being $180. + For the arm extension w/adjusters I wasn't about to do any grinding on them.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
#24 |
I found an example of the (Hellcat) wiring. Should be easy but how do I know which yellow wire is which (coming out of the 190)?
#25 |
Doesn't matter. Both yellow are lights
#26 |
Oh cool. So after more reading it looks like there isn't any way to make the cluster display which gear it is in but it will light up neutral?
Just to confirm, for the Hellcat nothing else is needed besides the motor? No special wiring harness, replacing the gas tank, weld a nipple to the bottom of the gas tank, special throttle body, oil catch, oil pump, oil cooler... etc etc. Just the motor, 2 bolts, 5 wires? |
#27 | |
If you really need a gear indicator there's an aftermarket/universal one that I bought (yet to install or test it though): https://www.amazon.com/dp/B07H7F8DKY/ref=cm_sw_em_r_mt_dp_U_VjaTCbP1VFX3C No special wiring harness is needed. Nothing involving the gas tank needs to be done, no throttle body and no oil pump. You do need an oil cooler, but the PitsterPro zs190 comes with one! Most places include it with the engine along with a Keihin PE28 carb knock-off. Highly recommend you run an oil cooler one since these are air cooled engines, not running one is very risky. You can find a spot to mount it on a bracket where your old airbox used to be attached to the frame. Oil catch can is also highly recommended at least while you are breaking the engine in. You'll get a lot of spit back coming out the crankcase breather tube...best to have it directed into a receptacle rather than all over your tires/chain/roads. |
#28 |
I've been reading that you can pull the gear sensor off of your 125 and put it on the 190. I'm still looking into that so I'm not 100% sure as of now. Yeah an oil catch can is a must during break in forsure.
#29 | |
I'm 95% sure on this. (I've read just about every post in the zs190 Swap Shop on Facebook lolol) If you connect the neutral wires via the harness connectors, it just makes it easier to disconnect everything should decides to go back to your old 125 engine. I think thats the only benefit. But hey I could be wrong on all of this! |
