04-03-2018, 09:32 AM | #16 |
I still have it, I cut the wires to the tail light pretty short but it's still usable
04-03-2018, 01:36 PM | #17 |
The tail light wires don't bother me much. I am mostly interested in the rest of the fender section. I will shoot you a PM.
03-07-2019, 07:14 AM | #18 |
rear fender
Good morning, greetings from Puerto Rico
Recently I bought the same enduro rear fender and I don't have any clue how to install it (specifically the wiring). I want to know if someone can help me with the instructions, will be very appreciated. Thnak you! |
03-07-2019, 08:22 AM | #19 |
We can definitely try to help. It should be a lot easier than you are likely thinking it will be.
03-07-2019, 10:03 AM | #20 |
Thank you for answering!
Black: negative Blue: running light/tail light Red: brake light I want to know with which wires are supposed to be connected. There’s are green, green with yellow and brown wires. |
03-07-2019, 10:27 AM | #21 |
Going off of memory.
Green is Ground. Green/Yellow Stripe is Brake. Brown is running.
03-07-2019, 10:43 AM | #22 |
And how can I connect the wires to the new ones?
There is a plug with the green, green/yellow and brown wire |
03-07-2019, 11:53 AM | #23 |
Simplest way would be to cut off the current connector and crimp on some weatherproof bullet connectors.
06-21-2020, 01:36 AM | #24 |
whats up yall im new to this
i recently bought a 2020 hawk and i was wondering if someone can tell me how to take fender off so i can put the fender eliminator kit on |
06-21-2020, 06:44 PM | #25 |
Man that looks good . Great job
