08-28-2009, 03:43 PM | #16 |
Start here, and see if it is helpful: http://www.chinariders.net/modules.p...ewtopic&t=4509
08-28-2009, 04:14 PM | #17 | |
After watched some of the video what's the main prupose of upgrade the stock oil pump to high volume oil pump? The 110cc don't even have a filter so what's the benefit from it? Will the motor runs cooler? Thanks |
08-28-2009, 04:21 PM | #18 | ||
In fact, the faster the oil runs past the components, the less heat it will wick away, so it would work the opposite. You have no need for high volume pump. |
08-29-2009, 07:32 PM | #19 |
Thanks again Turbo T,
I would have imagine that is not very useful too! |
08-31-2009, 02:05 AM | #20 |
spark plug repair
when you are drilling out the hole for the helicoil. use a good vacumm cleaner and place it as close as you can .. it will suck out all the filings.. and then when you are done .. crank it over with out any plug in it to flush out any other pieces.. you can always place some grease on a screw driver to help catch any pieces in the head when you turn it over by hand.. take the plug out of the left side and use a socket to turn it over.. taking the head off is a big job for this.. or let them do it.. they do this all the time.. no prolem
09-01-2009, 10:34 PM | #21 | |
Re: spark plug repair
I haven't decide should I do this myself of having it done by a shop. Will keep you guys posted. Thanks again! |
