Old 04-21-2017, 03:20 PM   #16
IAmTheRed1   IAmTheRed1 is offline
I'll chime in. I am running the PZ30 with stock exhaust and an aftermarket cone air filter. I am at sea level and current set is #40 pilot jet, #105 main jet, needle clip in the center slot, and 2 and 1/8 turns out on the mixture screw. I think I may still be slightly lean on decel so I may move the needle clip down one slot, or try the next pilot size. I think I have a #42 in the set I got off ebay.
Old 04-21-2017, 06:12 PM   #17
beyondhonesty   beyondhonesty is offline
Here is my plug, unknown jets (no marks), 2 turns out from "seated" on the mix screw.
Help please
12/2016 Rhino 250
Old 04-21-2017, 07:00 PM   #18
Mudflap   Mudflap is offline
Way rich. Choke all the way off? Air filter clean? Needle clip in the center position? Needle clip under the retainer clip?
Old 04-21-2017, 08:42 PM   #19
Choke is off, new filter.
The needle clip was in position #2 from the bottom, I have moved it to position #4 counting from bottom up. Seems to have helped the mid range a bit.
Retainer clip is present and in position.
Here is an updated plug with 3.5 hours of use with the new settings.
12/2016 Rhino 250
Old 04-24-2017, 08:40 PM   #20
Any ideas?
12/2016 Rhino 250
Old 04-25-2017, 08:09 AM   #21
Darth Racer's Avatar
Looks about right to me. Check it again after a couple more hours riding.
You look to be out of the rich zone... but want to keep an eye on it to be sure you aren't getting into the lean/hot zone.
