10-31-2009, 06:25 PM | #16 |
This is my tailight mod. I later wired it in to the headlight, was just testing here.
Its a 2 LED sucker and it comes on / goes off with the headlights. Pretty bright and a lot safer IMO. I dont want to hear one damn word about the screwdriver....fathers day gift from No.1 daughter and I have to use it now and again.
Good, Fast, or Cheap....Pick Two. |
10-31-2009, 06:34 PM | #17 | |
I am starting to fall off the fence...towards leaving it well enough alone (for once).
10-31-2009, 06:43 PM | #18 | ||
Now I know if I bought it from you I wouldnt have to do anything except start it up but jeez...look at all the fun I'd be missing out on...scraped knucks...hunting for washers...oil puddles on my garage floor...carb tuning with little pieces I can barely see...cross threaded bolts....the list goes on....you would take all that way from me???? Oh, I've heard the mini beast is the most invloved to assemble. If I could match whatever time you took, I'd consider myself lucky.
10-31-2009, 06:44 PM | #19 |
Nice taillight, i too considered a taillight for my son's 50, i was going to hook into the headlights and use a resistor and a diode so the brakelight would only come on 1/2 bright, i never completed it though.
How's the front end suspension on yours?, mine is very,very stiff, the back is good but the front, not so much. |
10-31-2009, 06:45 PM | #20 |
Hahaha.. I didn't even notice the pink 'driver til you mentioned it.
It's okay, I took my PINK 50cc for a burn this afternoon around the neighborhood. I'm sure I look more of a fool riding something pink, than you do twisting. |
10-31-2009, 06:52 PM | #21 |
Hey, it's halloween, anything goes
10-31-2009, 07:04 PM | #22 | |
10-31-2009, 07:07 PM | #23 | |
The Mini Beast comes with a lot of assembly.. the shocks, the exhaust and lots of grills and plastic pieces on top of what you put on for the mini atv. It took me 8 hours the first time, but that was because I was working blind without any previous knowledge of these things, and trying to make sure everything was 'perfect' .. the second one I did faster, maybe 5 hours but I had some fitting issues with it too. If you like assembly, the mini beast is for you. |
10-31-2009, 09:05 PM | #24 | |
11-01-2009, 07:45 PM | #25 |
How do the mini 110s compare in size to the hummer 110s? My girlfriends kid loves my 110cc hummer but he is 5 and it's too big for him to ride by himself. Are these smaller than the hummers?
Also I was just on the gio site and they dont even list the hummer atvs for sale anymore, so they must have been blowing out their inventory. |
11-01-2009, 07:55 PM | #26 | |
This mini with the 110 MUST BE GOVERNED for a 5yr old. The thing scoots, I mean REALLY scoots. PUT A TAILIGHT ON...I can see the kid going up the road from 3 blocks away now. Mine was commercial, but you can get em at C/T for 6 bucks. The 5yr old would just love it
11-01-2009, 09:13 PM | #27 | |
I've also seen a 5 year old (mine) not be able to control a 50cc mini atv like PCD's 110cc. It all depends on the child. If he can't control your mini hummer, he's more than likely not able to control the mini atv either. I tried to compensate on mine by tipping the bars closer to the rider so she could reach better, but I think it's presents even more bump steer/bar feedback which makes it even worse. |
11-01-2009, 09:35 PM | #28 | ||
I cant see 2 coils introducing ang significant sag and it wouldnt be a bad thing anyway. Will let everyone know how it works out.
11-01-2009, 09:40 PM | #29 |
I also have a new spare set of front spindles that i plan on extending 1.5"-2" to make my sons 50cc a little more stable, i know it works great on my 110cc T1 Rebel and my Beast when the front end is wider than the rear.
11-01-2009, 11:48 PM | #30 | |
Pete, I think the secret is to soften the spring, widen the track and eliminate bumpsteer. I swapped the front wheels around on my daughter's 150 Monster today before we went riding, and the dished rims provided a considerably wider track. It feels much more stable now. The next step will be to put the front end on a jackstand, unbolt the top of one shock and cycle the wheel up and down. As the wheel is moved through the suspension arc, the wheel will toe out at the top, straighten in the middle and then toe out at the bottom again. The trick is to mount the shock so that the wheel is just outside of toe out (at the bottom of the arc) when at rest. That way, the wheel will remain straight as the shock compresses. Right now, the front shocks on my daughter's quad are mounted too high in the arc (read: the shocks could be longer or they could be mounted further down). I'll either make a shock extension that screws into the upper mount, or I'll remount the shock mount a little lower. The by-product will be that the front end is raised a bit, but meh.
