08-28-2009, 02:39 PM | #16 |
And there wouldn't be. You'd need to change the wire from the coil to the plug to see an improvement. It's easy; peel back the boot and the wire simply unscrews from the coil. Just make sure to buy an NGK plug wire that suits your particular plug (stud vs. post type).
08-28-2009, 04:06 PM | #17 |
I was thinking maybe an over-rich condition except you have not made any changes to the carb. I would then be inclined to agree with others that think it is electrical in nature.
PS You recently moved, correct? Is there a difference in elevation? How old is the gas? |
08-29-2009, 12:19 AM | #18 |
gonna
Im gonna change out the cap and wire, also gonna test one of these new cdi's just to see.
Thx! will post results. :idea: |
08-29-2009, 01:21 AM | #19 | |
It's very common with these small single cylinder motors at higher RPM. Try running it without the filter, or airbox lid. If you can, try jetting it down a few numbers, like if it's a 100, go 95. See if that helps. |
