09-11-2022, 03:19 PM | #16 |
just look at it like the ignition is it’s own circuit and the lights and stuff are there own but yes you are basically making a new wire harness.. that’s the hardest part and what I mean by that it time consuming… the carb hawk has a 8 pole stator so you can’t just order Its stuff and plug and play… but come on it is a simple circuit.. over a weekend… very doable .. patience..
09-11-2022, 04:47 PM | #17 | |
07-04-2023, 05:14 PM | #18 |
Would you share a link for the gas tank you were able to fit? I'm doing the same conversion and was trying to gravity feed with the original tank that have the gas pump. But I can't get a good stream
07-04-2023, 10:12 PM | #19 |
Have to agree with alex, no way 85 mph. Maybe down a mine shaft.
