07-22-2015, 02:19 AM | #16 |
I studied engineering in college, so I developed a preference for the metric system forty years ago. I wish the United States had switched to the metric system in the 1970s, when Canada made the switch, but noooooooo.
07-22-2015, 06:36 AM | #17 | |
https://en.wikipedia.org/wiki/Gallon..._liquid_gallon
07-22-2015, 11:18 AM | #18 |
Try growing up in Canada. Back in the day, we used the Imperial system, we were inundated with the US system and we were in the process of switching to Metric.
07-22-2015, 12:49 PM | #19 | |
07-22-2015, 04:07 PM | #20 |
Just curious here, but SpudRider seems to follow CSC's recommend 2000 miles between oil changes. CSC recommends Mobil 4T Synthetic after the first 1000 miles and its my understanding that synthetic oils are suppose to last longer then mineral oils so does 2000 miles seem a bit excessive? What's Zengshon say on mileage because I don't see it in the PDF of the manual that's floating around?
07-22-2015, 11:24 PM | #21 | |
I change the engine oil every time the odometer turns 2,000 miles. This is the easiest way for me to remember to change the motor oil. I follow the same schedule for my Honda XR650L, but it has an air cooled engine. The used motor oil from my RX3 always appears to be in very nice condition. The fans and radiators on the RX3 do a very good job keeping the engine from overheating. I guess I am performing one extra oil change every 10,000 miles, but it is much easier for me to remember to change the oil every time the odometer records an even number of thousand miles. I use Mobil, Delvac, 15W/40 motor oil in all my motorcycles. It does an excellent job, and I don't see the need switch to synthetic motor oils. You might enjoy reading the following articles on motor oil. http://api.viglink.com/api/click?for...%20Oil%20Essay http://api.viglink.com/api/click?for...orcycle%20Oils
07-23-2015, 05:37 AM | #22 |
Synthetic oil?
I just completed 1,000 miles on my RX3 and switched to Mobile 1 motorcycle 10W-40. I use synthetic in all my bikes, not so much for longevity, but because the machines run noticeably smoother, and the increase in gas mileage more than offsets the cost of the oil. Now that I am running syn in the RX3, it's much much easier to find neutral. The bike runs quieter. I'm packing this morning for my first multi-day camping trip out to West Virginia and we'll see how the mileage turns out.
07-23-2015, 06:29 AM | #23 |
Quick tip for checking oil
Get a mechanic's inspection mirror -- one of the little round ones on a telescoping wand. I carry mine in the right saddlebag. Easy to check oil level while sitting on the bike.
07-23-2015, 12:54 PM | #24 | |
07-23-2015, 06:30 PM | #25 |
I do the same ... easy peasy!
09-26-2015, 04:12 PM | #26 |
Oil capacity?
Sorry to resurrect an old thread, and I think I saw this discussed somewhere else and can't find it, but what is the actual oil capacity of the RX3?
The CSC manual that came with the bike states alternately that the oil capacity is 1.7 quarts or 1.7 liters (apparently a proofreading problem), but then parenthetically states that both are 55.4 ounces. However, 1.7 US quarts is 54.4 fluid ounces, and 1.7 liters is 57.5 fluid ounces. Anybody know for sure which is correct? While I know that 2-3 ounces is not a huge deal in the grand scheme of things, I want to make sure I get it right!
2009 TW200 (first bike ever, sold it!);2015 RX3 Cyclone in blue (first "big kid" bike ) with 13T front sprocket, 19" front wheel, center stand, heated grips, LED aux lights, CSC skid plate |
09-26-2015, 04:48 PM | #27 |
The correct oil capacity is 1.7 quarts, or 54.4 fluid ounces.
I fill the crankcase with one quart of motor oil; then I add another 22 ounces. Every time I check the oil level in the sight glass, it is correct. However, you need to use the correct method for checking the oil level in a dry sump engine.
09-26-2015, 06:04 PM | #28 | |
09-27-2015, 08:03 PM | #29 | |
Oil pump and autopsie Nc250 / ZS177MM , (tomorow probably.. , mounted new bearings, and gear system 6.gear. ended im rported here new topic.) Maybe to give an idea Last edited by Co2; 12-18-2015 at 12:43 PM. |
09-28-2015, 12:02 AM | #30 |
Autopsy pics.
Thank You Co2 for sharing those. It helps to visualize the system.
I'm also impressed with the quality of the casting and machine work by Zongshen. One more *Chinese* myth set to rest. |
