#16 |
thanks a ton, i will do this when i have the opportunity, and get back to you on the results.. i do have a bit of a surge when i give throttle like its not pulling smoothly.. so maybe i am still running lean.... ???
My name is Justin, my friends call me Stix. 2008 Kawasaki KLR650 Candy Lime Green ______________________________ I am the official China bike registration Guru For the State of Maryland..... HA. |
#17 | |
Jason
#18 |
Sudco has the jets we need here:
http://www.sudco.com/keihin_mj.html#393 We need type 99101-393-xxx, so 2 jets up would be a 99101-393-112 (019-183). That's what I would recommend, or ream that bad boy out like I did for free!!!
#19 |
i love i when things are free. also i am going to be doing mostly soft sand and mud riding. i do not want to just have the uni-filter attached to the carb. so i was wondering would it work if i used the crate my bike is coming in to make a new air filter box. that box would be covered in slits to let air in but not on the bottom and contain the uni-filter. so i can keep splashing water out. and red you should post a video of how your bike sounds in action. i am really curious about that muffler.
#20 |
Chris,
Unless your new Lifan is really running like crap, drop the c-clip, adjust the carb and drill some holes in the muffler... As for me, I drilled the muffler out 2 5/8 holes, backed out the carb screw 1/2 turn and I sleep alot better now....
06 Lifan 200 GY-5 |
#21 |
people on here have said that the air box are brittle, attach poorly, and do not let much air in.
it is hard for my to keep anything stock. if i can fabricate something better, why not? but if anyone thinks this will not improve things, look better, or increase performance let me know. |
#22 | |
#23 |
thanks red.
#24 | |
#25 | |
Jason
#26 | ||
The bigger jet # means increased flow. It's not just the size of the hole that determines this. Different jet sizes may have the same size hole but different taper, and that changes the flow characteristics. Be careful with a drill. Remember doubling the size of the hole QUADRUPLES the flow of gas through it. The tip cleaners worked well because they have such small graduations between sizes. Looking at the jet, I couldn't even tell the hole was any bigger, I just know it is since the the files obviously took off a little material at each step. Two sizes up on files has made it plenty rich. I increased the hole diameter by about the thickness of a piece of paper maybe. The correct thing to do would be order new jets, but I had it all apart and didn't feel like waiting a week to get parts. And it was FREE!!!!!!!!!!!!!!
#27 |
not to mention that that site that has the jets says that they are selling them in quantities of 4 only.. so if 3 other people want to do this, i'll go in with you all to get some. Let me know.
#28 | |
#29 |
mdsuave13, I would go in with you.
Mark |
#30 | ||
