03-03-2019, 10:43 AM | #16 |
Sweet. frame looks cool.
03-03-2019, 11:08 AM | #17 |
There was a guy on here a while back that had a watercooled version and converted it to air cooled! LOL
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. |
03-03-2019, 11:11 AM | #18 | |
Did he give a reason why for his conversion? |
03-03-2019, 11:40 AM | #19 | |
Gonna look a lot like the bike on Ski rush's thread here.
03-03-2019, 02:43 PM | #20 | |
What were you saying here? Not sure I fully understood what you were saying. Please explain. |
03-03-2019, 02:56 PM | #21 |
Question on the Carb and Rear Shock
Here are more close-up pics of the carb. Please confirm that installing a new carb will be pretty much unbolt the old one and then bolt up the new one. I could be wrong, but I thought I either watched a video on YouTube or read a thread somewhere where the guy said even to remove the old carb, he needed to use a hacksaw to cut a slot in the bolt to back it off and then remove it. Does this sound right? Or, is it just a matter of unbolting (I'm hoping...).
Also, if you look at the last pic, you'll see where my preload on rear shock is set. Is this the lowest or highest setting? I'm thinking it's the lowest setting and raising the preload setting up will make it more firm; if that's the case I'd be surprised since it's pretty firm when I set on it now. Am I correct in this? |
03-03-2019, 03:54 PM | #22 |
nice pics, thanks for sharing. i really like the look of the bike, looks sturdy. interested to see how you feel about it as you go along. love seeing these new bikes being put together and living vicariously through you
03-03-2019, 05:07 PM | #23 | |
The rear tire is 130/80/17. All of the websites list the tire size a 110/70(front) and 130/70 (rear), but that's not what's on my bike. Last edited by Ski_rush; 03-03-2019 at 05:39 PM. |
03-03-2019, 05:20 PM | #24 |
Carb should be easy to remove. Fuel line, throttle cable. boot from air box clamp, remove 2 nuts holding carb to intake, and wiggle it out.
I think you might have read where some people have cut slots in the screws holding the bowl on the carb. If you do want to just take the bowl off to look inside, just take some vise grip needle nose pliers and you can get them out no problem. No cutting slots needed. Just watch very closely when you put the new carb on. That gasket between the carb and intake will only work one way. You will see what i mean.
03-03-2019, 05:53 PM | #25 |
I would say your shock preload is set to the highest position...moving the position up will lessen the preload and make it softer.
03-03-2019, 06:57 PM | #26 |
Thanks...thinking about it now, and logistically, that makes sense. I saw a video on YouTube on preload and it confused me.
03-04-2019, 09:21 AM | #27 | |
03-04-2019, 10:40 AM | #28 |
Love it. Nice looking bike. Regarding the fork protector, can you hit it with a blow dryer or heat gun and flex it into shape....if it's not adjustable? Most China fork protectors for USD forks have a top plastic collar that can be twisted to align them but your look a little different in the pics.
