01-25-2021, 11:30 AM | #16 |
That reminds me. A few years ago I had a Polaris atv that started not revving and it had a hole in the diaphragm.
It's bad to have a hole in the carburetor diaphragm but not as bad as having one in your wife's diaphragm. Lol
01-25-2021, 01:09 PM | #17 |
Yesterday I replaced the spark plug and started the bike up and it seemed much better, quicker startup and seems to have nice throttle response. I didn’t ride it yesterday though, so I’m not sure if it fixed the problem. I have a question, what is a EVAP canister and where is it? The only reason I still didn’t check the valve lash is since I don’t have gap tools to check the tightness. I will ride the bike today and give an update.
01-26-2021, 12:09 AM | #19 |
Youtube has a good maintenance video on valve adjustments for the identical tu250x. The xf250 has room to do valves without removing the tank, but doing so let's you inspect a vacuum line hidden between the tank and frame. That line should be plugged into the bottom of the tank, towards the front.
The Evap canister traps emissions vapors that can later be sucked out and burnt when the bike is running and the vacuum system is pressurized. It's a beer can sized black plastic cylinder with a handful of vacuum lines plugged into it. It's under the seat towards the back of the bike. If any lines come unplugged the bike would run like garbage.
2013 SSR XF-250 |
01-26-2021, 06:07 AM | #20 |
only an issue for CV carbs, not pull slide carbs like ours
01-26-2021, 07:39 AM | #21 |
True, but others in this thread are saying this bike uses a CV type carb and not a slide pull like most of our's use. The CV can develop leaks in the diaphrams.
01-27-2021, 06:44 PM | #22 |
True. This one uses a CV carb. The carb diaphram can also cause problems if it comes unseated from the channels it rests, easy to do during reassembly.
2013 SSR XF-250 |
Tags |
#help |
