Old 03-24-2011, 12:52 PM   #256
katoranger's Avatar
I noticed that wear on the original CST that my lifan had. I was thinking that was your reasoning for the rotation.
Old 04-01-2011, 01:42 AM   #257
About three weeks ago I decided to substitute chain rollers for the "chain slipper," and the chain guide slider on my XR650L. Today I inspected my chain guide rollers after 1,000 miles of wear. Here is a photograph of the front roller.
Here is a photograph of the rear roller.
Here is a photograph of both rollers.
I believe the sizes I selected for these chain guide rollers is very close to ideal, and I am pleased with their wear after 1,000 miles. The bolt for the rear roller had loosened a little, but it was still securely attached to the chain guide. Based upon these promising results, I am going to keep using these chain guide rollers.
The roller I substituted for the chain slipper looks almost new! I believe this roller is perfectly sized for this application.
Old 04-01-2011, 02:07 AM   #258
Spud, was that to preserve chain life? What was the original slipper material?
Old 04-01-2011, 02:12 AM   #259
I substituted the chain rollers because they are more durable than the rubber "sliders" they replaced, WaG. The stock, chain guard slider also produces a bit of friction, increasing chain drag. :roll: The chain rollers should require less inspection, and less maintenance. Also, the chain rollers should be less expensive to maintain.
Old 04-01-2011, 02:35 AM   #260
Thank you. I never thought of that.
Old 04-01-2011, 03:52 AM   #261
You're welcome. Here are some photographs of the chain roller I substituted for the "chain slipper."
This roller appears almost new after 1,000 miles of wear. I greatly prefer employing this chain roller to the stock, rubber "chain slipper."
Old 04-01-2011, 10:04 AM   #262
I can see where the stock slider would rob a little horsepower; that's a good idea. :idea:
Most Chinese 125 pit bikes use a similar system, but the rollers are of poor quality. Yours are clearly better; where did you find them?
Old 04-01-2011, 01:39 PM   #263
Thank you, WaG. Since I installed the chain rollers, my 520, X-ring drive chain seems to turn more easily when I lubricate it. Therefore, I think I have significantly reduced the drag induced by the rubber sliders. The chain guide slider on the XR650L is notorious for fast wear, and troublesome maintenance. :roll: When I bought this Honda it had 7,800 miles on the odometer, and the chain guide slider was badly worn. In fact, the chain was actually cutting a kerf in the bolts that held it in place, producing a great deal of chain fricition in the process! :x
Two of the chain rollers are Primary Drive rollers from Rocky Mountain ATV/MC. The smallest, most rearward roller is marketed by Moose Racing. If you wish, you can read my installation thread at the following link.
http://www.advrider.com/forums/showthread.php?t=667646
Old 04-01-2011, 02:01 PM   #264
Thanks for the education on chain rollers, Brother Spud! My KLX came with them, now I know enough to appreciate them.
Old 04-01-2011, 02:11 PM   #265
You're welcome, Brother Bill.
Old 04-04-2011, 01:25 PM   #266
davidsonsgccc   davidsonsgccc is offline
any reduction in drag on a smaller bike such as the zong sounds like possibly a noticable gain. i think i will try that. thanks for the idea.
my help may not be the best but it is free+-Seek ye first the kingdom of GOD
Old 04-04-2011, 11:02 PM   #267
You're welcome. Quite frankly, I think you could completely remove the chain guide on the Zong, and substitute a lower chain guard, such as the rubber "shark fin" on my XT225 swingarm.
I believe chain guides are necessary on larger bikes, with more suspension travel, to insure the chain will not become disengaged from the rear sprocket. However, I don't think a chain guide is needed on the Zong. As you can see, my XT225 swingarm doesn't employ a chain guide, merely a lower chain guard.
Old 04-05-2011, 01:19 AM   #268
I grew tired of cleaning the baked mud off my bike’s exhaust header. :roll:
Therefore, several days ago I installed a stainless steel, FMF, Hi-Flo header.
Based upon the color of the header, and my engine's performance, I think the stock, carburetor jetting is just about right for my altitude. What do you gentlement think? :?:
Old 04-05-2011, 08:43 AM   #269
JTCAndrew   JTCAndrew is offline
I Think it looks good. In Fact I'm curious what the seat height on that bad boy? I Probably wouldn't be able to touch ground but I'd love to see how much power that baby has.....Sweet Ride......I like it!
Andrew - Jamestown, PA 16134
YouTube Videos:
http://www.youtube.com/user/Jtcomp2009#p/u
2009 Qlink XF200 Supermoto
1982 Honda CM200 Bobber - SOLD
2003 JEEP Liberty SPORT = 3" Lift
2002 Chevy Trailblazer LTZ - Family Cruiser
Old 04-05-2011, 10:13 AM   #270
I think that header needs to be polished, but I have a compulsion when it comes to polishing metals.
It never occurred to me to read performance by header colour.
