#256 |
The bike seems to be running good now. Here is what I noticed.
1. The issue with the high idle seemed to be due to the throttle cable, not the carb. While I was adjusting the throttle cable I did notice the throttle seemed to be "wound up"; it's hard to explain. But, when the bike was off, I pulled back on the throttle a few times as I checked for the slack. On one of those turns, I noticed/felt it "release". Then the problem became that the throttle was too loose because I had adjusted it that way before the "release". So, this morning it wouldn't start because the throttle was too loose. 2. I did change the spark plug today. It did not come with an NGK plug. It came with a cheap looking plug. I installed the new plug. 3. Then, I worked on tightening the throttle some more. 4. The engine came back to life, and this time, at a more reasonable idle. I don't know if Enforcer17 had the same throttle issue, but to all who get an Enforcer, I would recommend cranking the throttle (with bike off) prior to starting it for the first time, and seeing/feeling if it "releases". |
#257 |
That's good advice and I'll be sure to do that. Probably a good idea to take the slide out and examine it and make sure it's operating smoothly too...I've read several posts of Hawk owners complaining about routing the cables so that things worked properly, and weren't binding, etc. too, so you're not the first by far.
And while that probably wasn't the ideal break in, all seems well. Did you get to ride it at all yet? I know it's colder than a witches teat here! ![]() |
#258 | |
I've read lots of your posts around here. Thanks for all your contributions. I've learned a lot from your posts. It's funny...I came across the enforcer on a Craigslist ad a few weeks ago, started researching Chinese bikes a little, and here I have one ordered already. Crazy...and that's what all my friends tell me who know how bad my back is...that I'm crazy. I honestly don;t even know if I can ride...but I rode a mountain bike all last summer, so i think I can ride a lightweight motorcycle...gently. And shit, someone called me and offered me a 2007 Honda crf230 for $1000...I had been looking for just that. It almost looks like a of of the parts would fit on the Hawk / enforcer. |
#259 |
MUCHO BETTAH!! Sounds great, looks good too. Nice job
#260 | |
#261 | |
I'm not really seeing a reason to buy a hawk over an enforcer at the moment. The enforcer seems like it's a hawk with all the upgrades that people normally do to the hawk anyway (e.g., better battery, gearing, and carb). Plus, it should be easier to register. Which brings me to my update...I just received all the paperwork from Don today! Enforcer gets registered first thing on Monday ![]() We'll see if it's as easy as it's claimed to be. |
#263 |
4-way flasher switch.
#264 |
The remote control with alarm is pretty cool!
#266 |
Good for you. I bet you love it and glad you found us.
#267 |
Single piston brakes on the Enforcer?
#269 | |
Welcome...and good...When enough of them get ordered they'll ship, and I'll get mine too ![]() |
#270 |
And to all of us new Enforcer buyers, there's a ton of great info regarding putting together a Hawk in the Sticky: Tech Favorites, FAQ's, & other things to know.
link at the top of the page, and probably most of it applies to the Enforcer. There's even an assembly video and tips on things that should be done, added, greased, etc. I just found it and it's definitely a must read |
